JUICEDMOTORSPORTS
Old 05-11-2013, 04:06 PM   #1
AmericanMuscleCars
Teenage Dream Camaro
AmericanMuscleCars's Avatar
Drives: A Visually Stunning Camaro
Need to wax my car but I have a problem...
I washed my car yesterday and I drove it and it rained a bit and got a little bit of water spots on the car and I wiped it off with meguiars ultimate quick detailer can I still apply wax or do I need to wash it again?
AmericanMuscleCars is offline   Reply With Quote
Old 05-11-2013, 04:08 PM   #2
dkp2LT
dkp2LT's Avatar
Drives: '10 2LT/RS, '13 GT/CS, '10 Flex
Personally I like to wash and wax at the same time for this reason. However I have in the past needed to wait the day - and I did the quick detailer and then waxed. So IMO I think you're OK.
dkp2LT is offline   Reply With Quote
Old 05-11-2013, 04:38 PM   #3
LuSe4
LuSe4's Avatar
Drives: 2013 Camaro 2SS RS LS3
If it was me, I would rewash. If you have any dirt on your car then you are going to be rubbing it all over the paint and potentially scratching the heck out of it. You could make a big mess if not careful.
-2013 Summit White over Inferno Orange 2SS RS-
-2014 White Diamond Silverado Z71 Crew Cab Short Box-
LuSe4 is offline   Reply With Quote
Old 05-11-2013, 04:42 PM   #4
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
wax has solvents in it that allow the carnauba to be carried. You don't need a 100% perfectly clean car to apply it. There can be polishing oils and all sorts of other stuff before you apply it.
If you do apply it, the wax may suffer in durability a little, but it's not going to be noteworthy. Don't overthink and just wax it
However, if you still have dirt on the car, that's a totally different issue. Then if you apply wax, you will rub the dirt into the paint and cause all sorts of damage. All I'm saying is that if the car is clean, but not surgically clean, it's ok to wax
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 05-11-2013, 04:42 PM   #5
AmericanMuscleCars
Gotcha, gonna wash it again... YAY... Not
Old 05-11-2013, 06:48 PM   #6
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
This is where you break out the waterless wash.
[B]
