Solo Performance
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > International Regions > UK
Old 05-11-2013, 07:52 PM   #1
DNAudus
DNAudus's Avatar
Drives: Bumblebee Camaro SS
How can I stop my manual forcing me into 4th gear?
Hi all,
I'm getting a bit hacked off with the "manual" gearbox always trying to force me to select 4th gear after setting off gently in 1st. It usually happens when driving in town and wont let me select second for about 3 seconds. It seems to be electronically moving a piece of metal in the way of second gear so that you can easily select 4th (but I don't want to).
Does anyone know if there is a way to stop it from doing this?
Cheers,
Damian.
DNAudus is offline   Reply With Quote
Old 05-11-2013, 07:54 PM   #2
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
Originally Posted by DNAudus View Post
Hi all,
Cheers,
Damian.
Search "skip shift,"
13 ZL1 is offline   Reply With Quote
Old 05-11-2013, 08:56 PM   #3
45thAnniversary2SS
45thAnniversary2SS's Avatar
Drives: 2012 45th Anniversary 2SS LS3
http://www.apex-speed.com/apex-motor...ator-8001.html
45thAnniversary2SS is offline   Reply With Quote
Old 05-12-2013, 05:04 AM   #4
Camaro Tom
Tomblebee
Camaro Tom's Avatar
Drives: Bumblebee Camaro 2010 Edition
Lol DNAudus join the club makes me rage aswell
Camaro Tom is offline   Reply With Quote
Old 05-12-2013, 05:16 AM   #5
stray bullitt
Drives: Bentley Continental GT.
You can buy fairly reasonably priced skip shift eliminator programmes from a couple of American tuning companies at least. If you go back to the main forum, and type in the search for "skip shift eliminators" there are a number of threads on the issue, which seems to cheese off a lot of people.
stray bullitt is offline   Reply With Quote
Old 05-13-2013, 05:57 PM   #6
DNAudus
DNAudus's Avatar
Thanks everyone. The solution offered by Apex motorsport looks pretty reasonable. I'll have a look around but I'm quite relieved it's only that much.
Cheers,
Damian.
Old 05-19-2013, 07:14 AM   #7
DNAudus
DNAudus's Avatar
Hi all,
So, I ended up buying the skip shift eliminator from gmpartshouse.com. GM Parts House is charging $23 for the skip shift eliminator but the USPS post costs $29! Weirdly, they have asked for a copy of my ID to complete the sale (which is something that I've never come across).
Does anyone know if I'm being ripped off for the postage, or is this the going rate?
Cheers,
Damian.
Old 05-19-2013, 08:51 AM   #8
jules1200
Drives: Delorean DMC12, Camaro SS
Probably about right for UPS shipping. I ship stuff all over the world, if you ask them, nicely they might label it as 'gift' otherwise you will have import duty & vat to pay as well. They will not normally clear it through customs till' you pay up.
jules1200 is offline   Reply With Quote
Old 05-19-2013, 10:15 AM   #9
Muddflap
Muddflap's Avatar
Drives: 2010 Camaro SS
Hi all,
Cheers,
Damian.
When it lights up on the dash just speed up a little more in first before shifting into second. The light will go off and will go into seco d just fine. That's the cheapest and easiest fix.
Muddflap is offline   Reply With Quote
Old 05-19-2013, 10:54 AM   #10
2Carats
2Carats's Avatar
Drives: '12 Camaro 2SS/RS LS3
Correctamundo! If you are traveling in 1st gear, once you get to 20mph, you'll be able to shift into 2nd gear. I do believe owner's manual addresses this as a "gas saving" feature that kicks in once your transmission temp reaches a certain temp.
Mind controlled by Cerebro
I solve problems for a living. Either accept my advice or go figure it out on your own.
2Carats is offline   Reply With Quote
Old 06-09-2013, 06:13 PM   #11
scites
Drives: 2010 camaro SS/RS
I have HP Tuners , so if you guys want we can tune it out. also play with VE tableand timing tables and get a little more power out of it..
scites is offline   Reply With Quote
