Caryle Racing
Old 05-11-2013, 08:44 PM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Crank Position Sensor. Help me find.
Ok, so my car killed on me at Starbucks. Took 6 or 7 times to get it to stay started. And the code once again was crank position sensor. Also threw a oil pressure sensor code this time. Oil pressure could have been because I kept having to restart it. (I was in the drive through line)
So which wire is it on the picture? All the wires look good and it's really tight. Changing it will be a major bitch looks like.
1. is a wire directly above the starter that you can't see.
2. is shown
3. is shown
Old 05-11-2013, 09:13 PM   #2
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
#2 is the crank sensor. Remove the starter and you can access the crank sensor easily.
#3 is the knock sensor.
LSX Camaro is offline   Reply With Quote
Old 05-11-2013, 09:14 PM   #3
PQ
Booooosted.
PQ's Avatar
Damn. What a pita.
How does that go bad? And with it inside the rest of the harnesses it's going to be a pain. I don't even know where it goes to.
Old 05-11-2013, 09:19 PM   #4
LSX Camaro
LSX Camaro's Avatar
The harness will unplug from the sensor, then use a 10mm socket to remove the sensor retaining bolt. You can leave the wires connected to the starter, remove the bolts and slide it out of the way. This will give you enough room to remove the crank sensor.
Old 05-11-2013, 10:06 PM   #5
PQ
Booooosted.
PQ's Avatar
Odd that a sensor can just go bad like that. Of course if this is my problem that I've had the past 2 years then I'd very much like that.
So I guess it's order time.
Oh MAUREEEEEEEEN.................... lmao
Rodgers Chevrolet to the rescue. hahahaha
Old 05-11-2013, 10:17 PM   #6
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
A quick check would be to backprobe the connector, one wire should have 5 volts + at key on, one wire should be ground and the other should have signal as you are turning the engine over by hand (socket on crank pulley etc). It should be on/off/on/off etc etc as the crankshaft reluctor ring passed over the sensor face.
if it doesn't register any signal, the sensor is probably bad, barring that the pin in the connector isn't getting a poor connection.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 05-11-2013, 10:42 PM   #7
CamaroLoco
CamaroLoco's Avatar
Drives: 2011 CGM Camaro SS
Damn. What a pita.
If it turns out that it's not the sensor (I replaced mine and it turned out to be something else), let me know.
CamaroLoco is offline   Reply With Quote
Old 05-11-2013, 10:52 PM   #8
LSX Camaro
LSX Camaro's Avatar
I have seen issues with the harness rubbing on the motor mount bracket/block. The symptoms sound like a faulty crank sensor IMO.
Old 05-12-2013, 12:28 AM   #9
fourmz
Fourmz
fourmz's Avatar
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28
Probably going to have to chalk it up to "S#%t Happens". My oil pressure sensor went out after 10 months. Replaced it and have had zero problems since.
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
fourmz is offline   Reply With Quote
Old 05-12-2013, 12:58 AM   #10
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Think about it this way. Everything breaks eventually. Eventually has to be sometime. Why not now?
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 05-12-2013, 01:55 AM   #11
PQ
Booooosted.
PQ's Avatar
Easier to just replace the sensor and see.
Ok.
Yup, I looked for any sign of that. I REALLY hoped to find some. But it all looks good.
I'd have to take the blower back off to get to the OPS.
Old 05-12-2013, 01:57 AM   #12
PQ
Booooosted.
PQ's Avatar
I suppose. Be nice to get it to quit dying under load at idle speed. AND to get it to not hesitate when gassing on it. It will just sit there for a small moment when I put it in gear and push the gas. Then just go.
Old 05-12-2013, 08:14 AM   #13
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Pq have you ever checked your ignition system?
Checked spark plugs?
TB?
Checked on a dyno?
Old 05-12-2013, 09:04 AM   #14
Doubleblank
Doubleblank's Avatar
Drives: 2010 Camaro SS, 2014 Z28
The old crank position sensor/check stabilitrac/ reduced power mode problem crops up again. Seems to occur for many when the battery is low or the starter is having difficulty turning the motor. I have it crop up occasionally since installing the ERL 500 cu in motor when the motor's hot, battery is hot......everything is hot. Once it cools down it will fire right up properly. We've pulled and checked everything. It's almost like the starter is pulling all the power/amperage from the battery and the ECU get's messed up temporarily. I'm going to run a larger gauge power wire from the battery first followed by a high torque starter.....if it will fit down there now.
ERL 500 ci Short Block, 2in ARH Headers, TSP LS7 Heads, LSXR/NW 102, Forgeline, MGW Shifter, StopTech BBK, Pfadt C/O's, Pfadt ASB's, etc, PowerFab Dynotune
Doubleblank is offline   Reply With Quote
