BeckyD@RodgersChevrolet
Old 05-11-2013, 07:55 PM   #1
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Pad Priming Discussion
Let's discuss some pad priming and what methods people use.
I personally subscribe to the Kevin Brown Method. This method is to completely cover the pad with polish and then add 3 drops of polish to start and then further as needed. Also, no detail spray on the pad is recommended.
In fact, there is a huge shift in the industry towards this method.
Mike Phillips (the face of Autogeek IE Blackfire, Pinnacle, Detailer's Pro, Diamondite, and other brands are all owned by Autogeek) and Meguiar's now also recommend this method.
And those are the only the ones I know of. I'm sure there are others.
The reason I subscribe to this method is the science behind it. For the first time, the science behind pad priming is clearly explained and the effects of those results are explained as well.
If you would like to read them, here is his link: http://www.buffdaddy.com/files/15195...g_Agents-1.pdf
Now this isn't to say other methods don't work, just that they can be improved upon.
So what method do you guys use and why?
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 05-11-2013, 08:38 PM   #2
ec1990
Drives: 2012 AGM SS
I like the KB method, although I do debate whether you need additional product before starting on the first pass. I like priming it by spreading it over the pad by hand then ensuring full coverage by using a 1 speed or so to spread the product to any missed areas. But I think that it's extremely difficult to use enough product to cover the pad, for it to soak in, and not have excess product in the pad.
Do you think MF pads should be primed the same way?
ec1990 is offline   Reply With Quote
Old 05-11-2013, 08:53 PM   #3
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
awesome
Old 05-11-2013, 09:14 PM   #4
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I didn't know it was called the Kevin Brown method, but that's what I do as well. Never really subscribed to the Adam's method.
[B]
Old 05-11-2013, 09:15 PM   #5
CamaroDreams07
Drives: Slow V6
Yes, go ahead and get some polish worked into your MF. I go pretty heavy and work it in with my fingers for the first section, then just a spray or two of Optimum Hyper for each subsequent section.
[B]
Old 05-11-2013, 09:27 PM   #6
ec1990
Drives: 2012 AGM SS
Yeah the first time I used it I got quite a bit of dust and I think it may have been a cause.
BTW what do you think of LC MF pads? They don't split up compounding and finishing MF pads, but I also heard the difference is purely the foam structure in them for Megs/Optimum ones.
But I do think priming is different for foam/MF pads just because you can overprime a MF pad where the the pad lays flat whereas you don't have to worry about that for foam pads.
Old 05-12-2013, 01:39 AM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Whether it works or not, it seems like a lot is going to waste, especially if you're cleaning your pad after every panel. If I was any of those companies, i'd be telling my customers use more product as well, whether it's needed or not. I definitely use more than what JM shows you in his vids but no where near the amount that the OP uses.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-12-2013, 10:15 AM   #8
ihaveacamaro
I like teeth.
Drives: #198
Did you read the link? It's not wasting if you are getting more efficient polishing is it?
Old 05-12-2013, 10:26 AM   #9
LIM3
LIM3's Avatar
Drives: SGM
Plus 1
Old 05-12-2013, 11:19 AM   #10
usranger80
usranger80's Avatar
Drives: 2011 1LT "Bumblebee"
How much do you guys really use? I have done 4 full PC's on my car since I got it and I still have more than 1/2 bottle left of all my Products, at this rate it will take four years to use it all, as far as effectiveness I have used Adams method and the KB method, didn't really notice a difference, they both worked just fine.
usranger80 is offline   Reply With Quote
Old 05-12-2013, 02:48 PM   #11
WiSSDiver
WiSSDiver's Avatar
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS
Still not convinced. Sorry, but I agree it's a waste of product, especially if your cleaning the pad every time. To me using this method over primes the pad and will only lead to a lot dust which equals more clean up time.
Just my opinion though. Certainly not the definitive answer.
WiSSDiver is offline   Reply With Quote
Old 05-13-2013, 03:10 AM   #12
axis
Search Ninja
axis's Avatar
Are you really getting more efficient polishing if you're completely saturating your pad, only to wipe half of it off after the first panel? Why would that be more efficient over priming the "old way" then wiping it off after every panel? Do you completely resaturate the pad after every panel?
I didn't read every word of that article but he said "my opinion" enough for me to come to the conclusion that most of this was indeed just his opinion. Whether it's sound or not, I didn't see much real scientific data here.
Halltech CF 102 fed
Old 05-13-2013, 03:50 AM   #13
CamaroDreams07
Drives: Slow V6
It's definitely opinion. I happen to agree with priming (NOT to be confused with saturating) a pad with polish prior to beginning. You do this once per pad, not after each panel. Once the pad is primed, it's primed.
I spray a few extra pumps of my Optimum polish on my clean optimum MF disc and massage it into the fibers. Then I give it a pump or two of polish for the first section.
With foam I spread a generous amount onto the pad and work it in. Then I apply my 3-4 dots and attack the first section.
I agree with quite a bit in the KB article, although it is just opinion we happen to share.
This isn't a junkman thread, so we can agree there is more than one way to get results. This is just one way that happens to work for Roshan, KB, and myself. And I guarantee you that even within this same school of thought, we all do it slightly differently.
Nobody is right or wrong as long as results are achieved, IMO. However, some of your posts indicate you did not read the article, because you're attributing things to this method that are specifically cautioned against within the text.
This article should be required reading for any paint polisher. Whether you agree or disagree at the end is inconsequential, the point is to get you thinking about what's going on rather than just hammering away with your machine and hoping for the best.
Now everyone give my thumbs a round of applause for tapping all this shit out on my phone.
Sent from my Galaxy Nexus using Tapatalk 2
[B]
Old 05-13-2013, 05:23 AM   #14
trm2
Drives: '13 Volt & '84 Vette
That good?
trm2 is offline   Reply With Quote
