Old 05-11-2013, 09:47 PM   #1
mcdoogle6969
mcdoogle6969's Avatar
Drives: 2010 Camaro SS, 2008 Heritage 300C
D1SC power number guess
Hi guys, I'm currently waiting on a D1 for my build I recently had a 2.8L Kenne Bell but I sold it.
With a built 416 stroker (factory block, eagle kit + JRE blower cam, L99 to LS3 conversion kit, ARP hardware, ect) and all the supporting mods needed...Anywho, through a A6 what power numbers should I see running boost levels around 12psi? Could I push the motor past that?
I'm just anxious to find out but the wait is killing me, parts need to show up NAO!!
mcdoogle6969 is offline   Reply With Quote
Old 05-11-2013, 09:56 PM   #2
Supercharged SS
Drives: 2010 Camaro
Is your trans still stock?
What fuel system? What's in the eagle kit?
I would say at 12 psi you'll be close to 650 rwhp. A6 sucks some rwhp up.
Old 05-11-2013, 09:59 PM   #3
mcdoogle6969
No trans will be built, looking at the LPE fuel system.
As for the kit I believe its eagle crank, H-beam rods, and I think Pistons are from them as well. I can't remember all the details since the shop I'm going through is taking care of everything. Also getting a fast intake manifold, heads are ported, 1000cc injectors, meth injection, and I'm going with the 12 rib pulley setup with their upgraded intercooler and such.
Old 05-11-2013, 10:03 PM   #4
Supercharged SS
Drives: 2010 Camaro
I'd crank the boost up to 15/16 psi if that blower is decently efficient at the level. Seems like the super charger will be the limiting factor. All the other parts are good to go.
Just keep in mind that the LPE duals are good to about 800 rwhp or so.
Old 05-11-2013, 10:06 PM   #5
mcdoogle6969
What other fuel system would you recommend? I would really like to break into the 700rwhp range but I think 800rwhp+ would be too much for me right now lol
Old 05-11-2013, 10:09 PM   #6
Supercharged SS
Drives: 2010 Camaro
If your staying between the 7-800 rwhp get the LPE duals. I've had it for three years now and it's been flawless. No problems what so ever.
Above 800 seems like the Squash is the ticket. I haven't explored those options because my car would be to fast with 800 rwhp!! It only makes 732 now.
Old 05-11-2013, 10:13 PM   #7
ToddB
Drives: 2011 2SS Convertible Supercharged
I think if you go over 700hp I can drive it till your ready - I am only 30 miles away.
2011 Camaro SS, LS3,Whipple SC, 13 PSI,CAI intake, ARH 2" Headers, Corsa exhaust, ZL1 fuel pump with ADM FPCM LS9 Cam and Meth,ID850, BMR suspension upgrades,Tune by JRE
ToddB is offline   Reply With Quote
Old 05-11-2013, 10:18 PM   #8
mcdoogle6969
Yeah I'll stick with the LPE, should suit me good enough!
Old 05-11-2013, 10:19 PM   #9
mcdoogle6969
I'll promise you a ride, but no driving for you
Old 05-12-2013, 12:57 AM   #10
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
12 psi should see close to 700 but the auto is gonna eat a good bit of power plus on a 416 you should have a F1 series Procharger to get the best out of your setup.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 05-12-2013, 11:16 AM   #11
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Originally Posted by Detoxx03 View Post
12 psi should see close to 700 but the auto is gonna eat a good but of power plus on a 416 you should have a F1 series Procharger to get the best out of your setup.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 05-12-2013, 11:35 AM   #12
Alvin@PCMofNC
Drives: 2010 IOM RSS
Have you bought the blower yet? If it was me I would skip to a F-1R. A D1 will be limited to about 750-maybe 800ish on that setup and while that might be too much now you'll grow in to it. A upgrade now is a lot cheaper than a upgrade later.
Alvin@PCMofNC is offline   Reply With Quote
Old 05-12-2013, 03:29 PM   #13
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Agree 100%
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 05-12-2013, 06:24 PM   #14
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
I'm doing OK on the stock bottom end with a D1SC.
If I were doing it now, I'd be looking at the new i1 from ProCharger.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
