Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > International Regions > UK
Old 05-12-2013, 05:28 AM   #1
Camaro Tom
Tomblebee
Camaro Tom's Avatar
Drives: Bumblebee Camaro 2010 Edition
Jacking Points?
Where are the correct jacking points on the camaro? I changed the wheels the other day, and will have to change them a couple more times, I looked in the manual which was no help. Where i jacked it up in the end was solid metal, however having a look under there appears to be a little circle area's around where each wheel is which would fit the jack perfect but it appears to be very thin metal, and with the weight of the car on it i can imagine it been unable to with stand the weight.
Camaro Tom is offline   Reply With Quote
Old 05-12-2013, 05:36 AM   #2
stray bullitt
Drives: Bentley Continental GT.
If you search the main forum, and type "jacking points", a lot of info comes up. Here's one to start you off. http://www.camaro5.com/forums/showth...jacking+points As well as the first few pictues here, if you go to the second page of this thread, you'll see a car photographed on its side, which I think should give you all the info you reuire.
stray bullitt is offline   Reply With Quote
Old 05-12-2013, 06:01 AM   #3
Camaro Tom
Tomblebee
Camaro Tom's Avatar
Cheers, I seemed to be jacking it in the right place for the front, but the rear i jacked it in a different position, the pic seems to show a much more smarter place to where i was jacking it lol
