Old 05-13-2013, 04:50 PM   #15
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
I have 18x10.5 c5 wheels with 56 offset, they fit with a small spacer perfect.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 05-13-2013, 05:22 PM   #16
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Drives: 2011 Camaro RS/2SS (L99) Synergy
Originally Posted by 3rdgen3 View Post
Okay..a lot of bad information in here...
First of all, WHICH C5 rims are you talking about? "chrome" doesnt give us a good indication of what wheel it is.
Are you looking for just 2x rear rims to use for drag tires? If thats the case, then ANY 18" C5 corvette wheel will fit on the REAR of our cars without issues.
I have seen C5 'wagon wheels' and C5 Z06 wheels on the back of our cars being used as a drag rim.
I personally have 18" c5 corvette wagon wheels for drag wheels. They fit just fine and 18" tires are a hell of a lot cheaper AND easier to find too! Offset is relative to wheel width and size too.. some 18x9.5" C5 vette wheels will fit the rear nicely.
If you're looking to mount all 4x vette wheels then thats a different story.
Good luck!
Hey guys,
Just trying to get a straight answer here so I don't miss a good deal. To be clear, I am ONLY using these for drag radials (rear only) and will only be installing them on days that I take it to the track, which will only be a few times a year. Here is a pic of what he sent me. Appears that these are the "stock" Vette rims (in chrome) off of a 2000-2004 C5 Vette? They are 18x9.5. I know the offset is NOT 40mm, but will these work is the question???? And, more importantly am I SAFE to do this knowing that I'm using them to drag race??? Makes me a little nervous to be getting such different replies.
Thanks!
John
11syn3rgy is offline   Reply With Quote
Old 05-13-2013, 05:36 PM   #17
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
You'd need to know the offset of the rims... 18x9.5/40mm C6Z rims fit in back without spacers (as I've read), and 56mm offset require a spacer because they tuck in more.
I might know someone in Kenosha selling some stock size (rear) 555R Nitto Drags half used if you are interested, pm me. I daily drive mine:
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 05-13-2013, 07:10 PM   #18
flyer08
Drives: 2010 2SS/RS
Originally Posted by 11syn3rgy View Post
Can you tell me what you have? What year are they off of and what size are they? Did you need spacers of any kind?
Thanks!
Just double checked them, 18x9.5 40mm offset
flyer08 is offline   Reply With Quote
Old 05-13-2013, 08:23 PM   #19
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
I've never seen that "style" of wheel tried before. Hard to say whether it will fit or not. Even if they are the correct 18x9.5 (+40), they might not have enough mounting pad height clearance to clear the calipers.
blazzin1 is offline   Reply With Quote
Old 05-13-2013, 09:02 PM   #20
Pro Stock John
Writer
Those are early C5 wheels or replicas.
PROJECT HEAVY CHEVY
Old 05-13-2013, 09:29 PM   #21
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
Hmm I have a pair of C6 rear 19x10 5 stars. I wonder if they'll fit with some kind of spacer
2011 L99 W/ Kooks Long Tubes, Ported TB, Roto-Fab CAI, MightyMouse can, Stainless Works 3" ZL-1 Catback, Overdriven Maggie @10 Pounds boost putting down 511/535 on a conservative tune.
Nutro is online now   Reply With Quote
Old 05-14-2013, 12:30 PM   #22
JEFF75645
Drives: his wife crazy buying mods
I just found a set of C5 wheels for $500. 18x8.5 56 offset and 18x10.5 50 offset.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 05-14-2013, 12:40 PM   #23
Pro Stock John
Writer
We used to call these wagon wheels not sure why, 1999 Corvette:
Jeff both of those would need a spacer per the info on the web. The latter and variations of it get used often I think on here. Anyone know what size spacers folks run.
PROJECT HEAVY CHEVY
Old 05-14-2013, 12:47 PM   #24
JEFF75645
Sorry for the thread jack
Thanks John. The have good Michelins monted on them. Is it safe to race with spacers?
Old 05-14-2013, 01:09 PM   #25
Pro Stock John
Writer
Depends... How thick of a spacer?
And it also comes down to thread engagement, would you have enough thread to secure the lugs.
Historically I've raced with a small spacer, but I watch that thread engagement and if there is not what I think is enough, I would change the combo or run longer wheel studs.
PROJECT HEAVY CHEVY
Old 05-14-2013, 09:05 PM   #26
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
no one has mentioned, the vette wheels will work, but THEY are not an exact fit, the lug spacing on the camaro and the vette are not the same...vette is 5x 120.65 aka 5x4.75 and the camro is 5x120mm...like i said the rims will go on and will tighten down, but i would be safe and torque them and check torque after evry run...only takes a minute and better be safe then sorry...and i posted earlier the zr1 rims would fit ..that would be incorrect...the correct rims that fit the camaro with best offset is the zo6 and grand sport rims...there are tons of aftermarket which usuall runs 56mm offset , which will not work
mikepage0007 is offline   Reply With Quote
Old 05-15-2013, 11:36 PM   #27
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Thanks guys. I pulled the trigger on some stock polished 20's off of a 2013. Getting them on Monday. Now I just need to find some drag radials.
Old 05-16-2013, 09:32 AM   #28
Pro Stock John
Writer
That guy in Kenosha might still have his.
PROJECT HEAVY CHEVY
corvette, drag, tires
