JDP Motorsports
Old 06-26-2009, 11:52 AM   #1
CamaroKitty
Drives: 2010 Silver Ice 2LT RS V6
Clacking sound on cold cranks! HELP PLEASE!
When I first crank, I have a sporatic clacking noise that will continue until the car idles down. This takes a few seconds only. It only happens on cold cranks. After the first crank of the day...it doesn't do it again. Also..you can har some belt nosie non stop from the time of crank and even after it idles down. Any thoughts??
CamaroKitty is offline   Reply With Quote
Old 06-26-2009, 02:35 PM   #2
camaro5's Avatar
Drives: 2019 Louis Chevrolet Camaro
It's called piston slap.
Common in many GM engines.
Around 1998, GM switched from a "Select Build" method of manufacturing and/or assembling engines to a "Net Build" method, in order to save money on manufacturing and/or assembly.
In the Select Build process, pistons and cylinders are matched for size and fit. GM's new "Net Build" method of manufacturing and/or assembly, in contrast, assumes all pistons will fit equally well in all cylinders and does not allow for variations in the size of engine cylinders or pistons.
The pistons of slightly varying size (all within spec) are not individually matched with the cylinders of slightly varying size (all within spec).
Excessive “piston slap” occurs because an automobile manufacturer (GM) designs and/or manufactures a engine in which the clearance between the piston and cylinder bore is too great.
Essentially, the piston moves sideways and “slaps” or “knocks” hard against the cylinder bore.
http://www.pistonslap.com/
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP Graduate, A.S. Automotive Technology, Telecommunications Specialist, CISCO Certified Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to,
any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 06-26-2009, 03:19 PM   #3
CamaroKitty
So what do you do?? It sounds horrible. Is it something that the dealer needs to go in and fix or do you just deal?? It didn't do it for about the first few hundred miles.
Old 06-26-2009, 07:20 PM   #4
camaro5's Avatar
My then new, 1984 Camaro Z28 did it too.
I would just deal with it. I bought a new Corvette knowing all about it.
I don't like it though...
The link I posted has all the info, as they are dedicated anti piston-slappers.
STANDARD DISCLAIMER
Old 07-02-2009, 07:03 PM   #5
caramaro1969
caramaro1969's Avatar
Drives: 69,82,84 & 10 camaros,87 GMC,07z06
yeah it's a ls motor thing.it has been known to do it with other gm motors.no worries
caramaro1969 is offline   Reply With Quote
Old 07-02-2009, 07:08 PM   #6
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
I have the same thing on my 2004 Silverado, nice little knocking sound but it is consistently there.. Faint.. but there all the time.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 07-02-2009, 07:11 PM   #7
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
I doubt that "piston slap" is the issue. More likely noisy lifters until the oil pumps up top. No big deal. Still, it doesn't hurt to get the dealer to have a look.
The site listed is there to MAKE MONEY. Lawyers run it to advertise LAWSUITS so THEY can get paid..
patriotpa is offline   Reply With Quote
Old 07-02-2009, 07:22 PM   #8
Rogue Leader
Iatefiberglassinsulation
Rogue Leader's Avatar
Drives: 2010 Camaro 2SS M6
Yeah those sites go nuts over the piston slap issue and say it destroys the engine... Ive had 2 LS motors with 100k on them and both pistion slapped while idling cold, neither one used a drop of oil, and both ran mint otherwise...
Like he said lawyers trying to make money...
2010 Chevrolet Camaro SS - was daily driver, now toy
2014 Mercedes Benz E350 4matic Sport - Daily Driver
2008 Chevy Silverado 2500 HD LT 6.0 - Tow Vehicle
1995 Volkswagen Golf Race Car
"Like" my race team on Facebook: http://www.facebook.com/farfrumwinnin
Rogue Leader is offline   Reply With Quote
Old 07-02-2009, 07:23 PM   #9
PsyDoc
Drives: Soon-to-be 1st Gen
No worries? Really? So, a piston that wobbles in the cylinder bore is nothing to worry about?
PsyDoc is offline   Reply With Quote
Markups = NO Camaro. 350(V8) = Camaro Like Sound One Mean Chevy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 07-02-2009 12:03 AM
How is the Camaro Sound System? 2Muchmark Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 14 04-27-2009 01:23 PM
Surround Sound Help! T! E! X! A! S! Off-topic Discussions 3 01-24-2009 06:55 PM
Sound check MustangKillr 4th Generation Camaros 8 10-08-2008 10:54 AM
Muscle car exhaust sound linkwpc 5th Gen Camaro SS LS LT General Discussions 19 12-09-2007 07:50 AM
