JUICEDMOTORSPORTS
Old 05-13-2013, 12:57 PM   #1
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Vortech V3 info
For those of you that are supercharged and looking at going with more boost, I was looking at Vortech's site and found the following:
Superchargers exceeding 6 PSI require a Vortech standard bypass valve or a Vortech Maxflow racing bypass valve.
Superchargers exceeding 10 PSI require a Vortech Maxflow Mondo or Maxflow racing bypass valve.
http://www.vortechsuperchargers.com/page.php?id=30148
BaylorCamaro is offline   Reply With Quote
Old 05-13-2013, 01:06 PM   #2
V6owner
Cedar Creek Woodshop
V6owner's Avatar
Drives: One Badass 1LE
Great info!
2014 Black 2SS/RS 1LE
V6owner is offline   Reply With Quote
Old 05-13-2013, 01:12 PM   #3
V6owner
V6owner's Avatar
I regular blow off valve wouldn't be efficient enough?
Old 05-13-2013, 01:50 PM   #4
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Old 05-13-2013, 02:27 PM   #5
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
Blow off valves are for turbochargers... You can change the BOV spring out to a light spring and make it a bypass valve.
Matt @ FSP is offline   Reply With Quote
Old 05-13-2013, 03:39 PM   #6
RBD
RBD's Avatar
Drives: 2013 SS/RS Convertible
for high boost JRE recommends two BOVs........
RBD is offline   Reply With Quote
Old 05-13-2013, 10:46 PM   #7
Adadda
Drives: 2012 Camaro SS. L99
[QUOTE=RBD;6538758]for high boost JRE recommends two BOVs........[/
Get a Vortech BV57 for high boost. Looks a lot better. Too.
Adadda is offline   Reply With Quote
Old 05-14-2013, 09:26 AM   #8
stand-al0ne
Rev Couture
stand-al0ne's Avatar
Drives: 2010 LS Camaro & 2013 Rav4 Ltd
I dont think 10psi is considered high boost...
EBC Brakes| DOT 4|Bigworm| SickSpeed| BMR | IPF | Vararam| MRT |MGW | Nitto | Rx |
Iggee |ZL-1 Sways| Hurst | Apex Racing|Past: Srt-4| 6.0L GTO- RIP | '98 Integra
stand-al0ne is offline   Reply With Quote
Old 05-14-2013, 06:27 PM   #9
kuzman89
kuzman89's Avatar
Drives: Ly7
What size pulleys have you guys got standard on the v3s. And how much smaller is the pulley if you want 10psi?? Ive got 3.6" stock.and wanting 2.8 to 2.95"
kuzman89 is offline   Reply With Quote
Old 05-14-2013, 06:35 PM   #10
Matt @ FSP
Matt @ FSP's Avatar
3.25" will run the blower a bit above the maximum rated impeller speed.. So I would not run a V3 Si or T with lower than that.
Old 05-15-2013, 04:17 AM   #11
kuzman89
kuzman89's Avatar
Drives: Ly7
Thanks for the information. I've got a V2 with a 928 impeller and some upgraded parts and been told max speed is around 62k rpm. With the impeller speed calculator says 2.9" will run about 56k but just don't know about belt slip.
Old 05-15-2013, 11:07 AM   #12
Matt @ FSP
Matt @ FSP's Avatar
Sorry I stand corrected on what I had said. With the 7.9" lower, it will run about max rpm.
So what "kit" are you actually running? This is the BIG determining factor on belt slip.
