sjm autoprod
Old 05-13-2013, 01:09 PM   #1
trans665
trans665's Avatar
Drives: 2010 2ss
m6 tranny fuild???
can some one tell me what kind of fuild do i get for transmission m6.. i just did a cam install and need to top it off
trans665 is offline   Reply With Quote
Old 05-13-2013, 09:28 PM   #2
Stealth6
Drives: '17 GT350
Fluid type: Texaco ATF Type III 1863 http://www.camaro5.com/forums/wiki.p...tions+%28SS%29
Stealth6 is offline   Reply With Quote
Old 05-13-2013, 09:52 PM   #3
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Please note that the above is for V-8 cars only! The V-6 cars use 75W-90 gear lube.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 05-13-2013, 10:05 PM   #4
Chevy69er
Chevy69er's Avatar
Drives: 2011 SLP ZL-585, 13' Silverado
I'd change it out with some royal purple. Will help with the second gear grind!
Chevy69er is offline   Reply With Quote
Old 05-14-2013, 10:39 PM   #5
jag107
jag107's Avatar
Drives: 2010 2SS/RS IOM M6
Royal Purple what? Wanna swap my fluid sometime.
Placed order: 02.25.2010
Took delivery: 04.06.2010
Halltech Yellowjacket CAI, Mike Norris catch can, VMAX PTB, JBA Shorty headers Hi Flow cats & axleback, Magnaflow Tru X pipe, Eibach F&R sway bars & end links
jag107 is offline   Reply With Quote
Old 05-16-2013, 07:22 PM   #6
james347
Drives: 2006 Crownline
http://royalpurpleconsumer.com/produ...mission-fluid/
james347 is offline   Reply With Quote
Old 05-21-2013, 09:24 PM   #7
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
RedLine D4 ATF will smooth out the trans real nice. Plenty of posts on it, its the best stuff for the V8 manual trans. I've been running it for over 60k, awesome stuff.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 05-23-2013, 07:09 PM   #8
denooo11
Dean Voss
Drives: 2010 Camaro SS
Send a message via AIM to denooo11
Trans fluid
If you have a m6 use automatic transmision fluid I used redline atf. The best fluid you can put in your M6.
denooo11 is offline   Reply With Quote
Old 05-29-2013, 07:43 AM   #9
Hannibal
Hannibal's Avatar
Drives: Camaro SS & ZL1
I too used Redline D4 in my Tremec TR6060 and the difference is amazing.
Hannibal is offline   Reply With Quote
