SDTW Custom Wheels & Tires
Old 05-13-2013, 05:37 PM   #1
bct10985
Drives: 2010 2SS LS3, 2013 duramax
timing and iat
Those with centrifugals what kind of iats are you seeing and what is your total timing at wot?
ECS Ysi-B, FSP cam, Tsp 2" longtubes, Squash dual pumps, Id850s, Aem meth, Jakes stageIII 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 17" weld rts 4.5" M&H skinnies front, carlyle racing 15" conversion mt 325 et street R. 9.8@143mph
bct10985 is offline   Reply With Quote
Old 05-13-2013, 08:32 PM   #2
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
My timing was about 17-19 deg at WOT with IATs at about 115-120.
Pat G, my tuner set it up to pull timing at IATs above about 55 deg C or 135F
Fully built/forged motor though!!!!!!!!!!!!!!
AFRs were very conservative at 10.8-11.0
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 05-13-2013, 08:41 PM   #3
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
Timing depends on IAT in my tune. On a 65 degree day, I see IAT at the top of 2nd gear at 114 degrees and timing at 14.5 degrees. By the top of 3rd I see IAT at 159 degrees and timing at 11.5 degrees.
I am surprised to see timing pull that much with that temp but I guess that is what is safe. I'm also surprised to see IAT's climb that much, but is still better than the top mounts I've seen. This is with a Vortech Si trim ECS kit, 12 lbs of boost on a stock cammed L99.
What is everyone else seeing for IAT's after a 1/8th or 1/4 mile pull in 60 or 70 degree weather??
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 05-13-2013, 09:44 PM   #4
bct10985
My iats were getting up to 160 on the dyno and my tuner said it would only accept 8 degrees of timing before knock sensors would pull timing. He acted kinda shocked and asked what octane and where i got the gas from. Royal farms 93.
Old 05-13-2013, 09:48 PM   #5
dan0617
dan0617's Avatar
I am at 11.2 AFR running 93 octane 10 percent ethanol. Gauge set for 14.2 stoich. I am down to 11.5 or 12 degrees timing at 160 IAT. 6200 rpms 12 psi boost. No knock retard.
Stock l99 stock cam.
8 degrees seems a little low. Make sure your AFR is no leaner than 11.7 with normal gas calibration and fuel that has ethanol blended.
Old 05-13-2013, 10:31 PM   #6
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
I dont think IAT's should get that high with a centri. Even with my eforce I never see 160.
I am running 94 octane, 10% ethanol, , 12 lbs of boost, 18 degrees of timing, and afr around 11.8 . This is on a forged motor and meth, which can obviously take more timing than a stock engine.
By 158 I am pulling a ton of timing, just in case but I never expect to see those temps.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 05-14-2013, 07:45 AM   #7
bct10985
Matt from fsp thinks it could be that their dyno didnt have good enough airflow and that you would never see iats that high on the street. I dont know why im looking for more power the thing just blows the tires off as it is lol
Old 05-14-2013, 08:33 AM   #8
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
With ported heads, 9.5CR, stage II intercooler, and 104 unleaded, I see 160* (at 6800 rpm and 130mph+ at the top of fourth) and 18* timing with no knock-reduction.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 05-14-2013, 08:58 AM   #9
dan0617
dan0617's Avatar
I see 160 IAT on the street at the top of 3rd after a WOT pull starting from 1/2 way through 1st gear. Not the dyno.
Old 05-14-2013, 09:02 AM   #10
dan0617
dan0617's Avatar
With an air to air IC centri, or with a normal intercooler on a top mount, I'm betting there isn't a setup out there that stays below 160 IAT on a 70 or so ambient day.
Everyone I see below 160 is fancy intercooler, AC setup, meth, etc.
Old 05-14-2013, 09:06 AM   #11
dan0617
dan0617's Avatar
Cam and compression have ALOT to do with timing. Meth has ALOT to do with IAT. Turn the meth off and let us know what your IAT and timing is at the end of a 1/4 mile run just before you lift off the go pedal. Ill bet you see well over 160.
Old 05-14-2013, 09:38 AM   #12
Alvin@PCMofNC
Drives: 2010 IOM RSS
I would make some changes ASAP. A good cam will allow you to run more timing at the same boost than the stock cam..Especially if you have a L99. Please let us know if we can help with the cam.
Other than that I would go up on the pulley size (less boost) I feel really uncomfortable if I cannot get at least 12-14 degrees of timing in a setup and the reason is this...
Combustion releases energy in a combination of two ways. 1. Expansion work (good) 2. Heat (not so good) The later the timing the more the combustion cycle misses out on expansion work because the majority of the expansion happens relatively soon in the cycle at around 28-35 degrees after top dead center. So what is happening the energy released misses its chance to be expansion work and so is only option is to become heat. This is putting more heat into the exhaust valve, plugs, headers/manifolds, cats, etc!
What I'm getting at is the later the lead, the more your going to start cooking everything else!
Alvin@PCMofNC is offline   Reply With Quote
Old 05-14-2013, 10:01 AM   #13
realcanuk
realcanuk's Avatar
I had my supercharger without meth for over a year.... saw about 140 at the end of a run. .
Old 05-14-2013, 10:29 AM   #14
bct10985
Its an ls3
