Solo Performance
Old 05-13-2013, 09:45 PM   #1
funk69z/28
funk69z/28's Avatar
Drives: 2011 SS/RS n 1969 Z28
A cam that will give solid torque numbers
Hey guys we all know that 500hp is a awesome number. With all the solid cam choices out there my mind starts to spin. But one thing that I keep thinking about is just how heavy this car is and how valuable torque is to get her rolling. I would give up a little top end hp for more grunt under the curve. Does anyone have experience with a solid torque monster cam?
1969 Z/28 DZ302 95% Stock
2011 SS/RS Slowly becoming not stock.
funk69z/28 is offline   Reply With Quote
Old 05-13-2013, 09:57 PM   #2
The Blue Ox
The Blue Ox's Avatar
Drives: 2010 SS L99 Inferno Orange
The Blue Ox is offline   Reply With Quote
Old 05-13-2013, 10:32 PM   #3
Ucantctchme
Ucantctchme's Avatar
Drives: 2010 ss. 1990 RS the faster one.
Vengeance Racing cam 439 to at the wheels. Not sure where that stands. I changed the gears right before I put the cam in. The gears helped tremendously down low.
Vararam, XS Power longtubes and exhaust with Magnaflow mufflers, 1LE gears, Vengeance Racing spec'd comp cam with all supporting valvetrain upgrades, Melling Pump. QTP cutouts. 480rwhp.http://i64.photobucket.com/albums/h179/ucantctchme/d5c3102c.jpg
Ucantctchme is offline   Reply With Quote
Old 05-13-2013, 10:33 PM   #4
black79ta
black79ta's Avatar
Drives: 79 transam with 582cid dart motor
Bump??
2010 Camaro (inferno orange, 2SS, RS and such)
cat backs, catch can, CAI on the way
79 Transam, 582 cid dart motor 779hp 315's out back 40spline gdaxles tko tranny
black79ta is offline   Reply With Quote
Old 05-13-2013, 11:14 PM   #5
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Get some 3.91 gears and that low end torque will take care of itself. It's a good compliment to most cams. I hear the nightfury cam is impressive.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 05-14-2013, 12:02 AM   #6
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Exactly! Getting the smaller gear gives you a lot more room to play with in your new cam. The smaller gear you go with, the lower in the band you'll hit the peak power in the curve. I think anyone that wants to remain N/A should do gears or the gear/cam combo.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 05-14-2013, 12:11 AM   #7
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Honestly its a pretty big cam but if you study the torque curve of the Night Fury cam its pretty impressive. If someone would post a graph for a LS3 car you will see what I mean. That cam is probably not going to drive like stock or anything but its torque production looks to be more than the smaller cams even at lower RPM's.
Old 05-14-2013, 01:20 AM   #8
Ivan @ Southwest Speed
Gears first....then the Cam.
Lots of Cams that will hook ya up, but the gear selection will definitely help it out exponentially.
Hook ya up a set of 3.91's and roll out.
Ivan
Old 05-14-2013, 01:44 AM   #9
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
3.91s and the GM asa cam. Be prepared to buy new rear tires on occation.
Bo White is online now   Reply With Quote
Old 05-14-2013, 04:49 AM   #10
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
I hope not. Those Goodyear f1's are expensive!
Old 05-14-2013, 07:26 AM   #11
funk69z/28
funk69z/28's Avatar
This is one of the cams I do like.
Old 05-14-2013, 07:27 AM   #12
funk69z/28
funk69z/28's Avatar
Exactly what I was gonna do. Thanks for the tip
Old 05-14-2013, 07:28 AM   #13
funk69z/28
funk69z/28's Avatar
Specs on the gm Asa cam or where can I go to see them?
Old 05-14-2013, 08:21 AM   #14
Bo White
Bo White's Avatar
Its actually an old grind. 226/236 I believe with .525 lift. Its on a tight 110 seperation which is the main reason for the torque. Doesn't make big #s up top though.
