Old 05-15-2013, 03:05 PM   #29
drayco513
drayco513's Avatar
Drives: ss2/rs
the lg g6x3 puts up some awesome tq numbers and it dont fall off to bad either. my car didnt make what most do with the cam . but it was crazy hot and had a intake leaking causing problems but it still made 461/423 . i thinking now i should be up around 490/450 . n/a cause my car is trapping 119's with the new intake and a few other lil changes. the 107 degree temps that day on the dyno killed it out.
u cant hardly see the time slip but that was on street tires and nothing pulled out of the car and 93 fuel. da was around 1200 if i recall.
drayco513 is offline   Reply With Quote
Old 05-15-2013, 03:31 PM   #30
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
11.3 on streets? damn props man I cant figure out how to get mine to launch at all.
it flat nukes the Nitto Invo 315s even bagged at 18psi and thats coming out near engine stall and then rolling into it.. just goes sideways.
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 05-15-2013, 04:09 PM   #31
KARBON
KARBON's Avatar
Drives: 2010 CAMARO 850 RWHP/733 RWTQ
You will never hook with the Invos and the power your car puts down. Mickey or NTO5's will get you there. Preferably 18"
*Night Fury
*Vortec YSI
*Alky Meth
*RPM TH400 with Brake
*Precision 3600 Converter
*850 RWHP/733 RWTQ
KARBON is offline   Reply With Quote
Old 05-15-2013, 04:11 PM   #32
DuskSS
DuskSS's Avatar
Thanks karbon I suspected as much.
gotta get those axles and bushes done and buy some 18s for messing around at the track.
will stabilitrack have a fit with 18s on the rear and 20s on the front? or will it be ok for track only?
530/520 SAE
Old 05-15-2013, 04:19 PM   #33
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
nightfury all the way 1320 :P
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK
9in. diff with 4.11's, DSS Axles, and Alum Shaft
Hurst Short-Shifter; Ideal Garage Master Cylinder
H-E Street Slayer Twin Billet Clutch
BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings.
Strange Rear Coilovers and mounts
Tuned by Rhino79
Medi0cr3 is offline   Reply With Quote
Old 05-15-2013, 05:31 PM   #34
BLACK10
BLACK10's Avatar
it will be fine since the overall height is about the same
Old 05-15-2013, 06:21 PM   #35
drayco513
drayco513's Avatar
Drives: ss2/rs
11.9 on streets . 11.3 would be rockin lol
Old 05-15-2013, 06:33 PM   #36
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Right, just do the 305/45R18 and your car wont know the diffence driving to the track and back. Of course you wouldnt want to DD like that but will be fine to and from the track.
Old 05-16-2013, 08:38 PM   #37
funk69z/28
funk69z/28's Avatar
Drives: 2011 SS/RS n 1969 Z28
I am going to get my car on the Dyno this weekend with my current mods- RotoFab intake, TSP LTH, FLowMaster 3 inch AMT cat back, and my JRE tune. I will post up the results.
I am Leaning Towards 3 cams
1-the "545" Cam
2-The All Mighty "Night Fury" Cam
3-And the Latest and Greatest from TSP Texas Speed LS3 235/239 .639"/623" Camshaft
Leaning Towards the Brian Tooley Plat Springs--Already have the ARP Bolts, 3 bolt cam car, ls2 dampner, GM Gaskets, and melling oil pump.. Also will pick up a c5r chain. Not sure if I am going to do the rocker arm upgrade. Some say it is needed some say it isn't.
What I like about TSP is they test there stuff on a engine dyno. A few of the guys I know run there stuff. Cant Deny the Night Fury's results, and that 545 cam doesnt get the press like the others, but looking at it and the results seem solid.
1969 Z/28 DZ302 95% Stock
2011 SS/RS Slowly becoming not stock.
funk69z/28 is offline   Reply With Quote
Old 05-16-2013, 08:47 PM   #38
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
1-the "545" Cam
I'm actually getting my cam installed by PCM of NC next month trying out their '545' cam with my setup. all of the dyno sheets and videos I've seen on it seem solid and a great streetable cam with good power. As for you, I wouldn't "lean" towards the BTR springs or trunnion upgrade, I highly advise you to get them. I don't know Who told you upgraded trunnions weren't needed, but they are trying to set you up for failure.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 05-17-2013, 12:10 AM   #39
VADER SS L99
I say get the trunion upgrade. Its a small expense for piece of mind.
Old 05-17-2013, 02:06 AM   #40
coreyaustin17
NEC5 C-HOLE CHAMP
coreyaustin17's Avatar
Drives: 2013 camaro 2SS/RS 1LE 1 of 221
Originally Posted by lsuguy View Post
Night Fury LS3 curve. I later added 3.91s and it drives better than stock to me
very impressive curve any other mods?
coreyaustin17 is offline   Reply With Quote
Old 05-17-2013, 09:09 AM   #41
LeanPocket
Drives: 2010 2SS
yes, get the trunion upgrade. You cant put a price on peace of mind.
LeanPocket is offline   Reply With Quote
Old 05-17-2013, 02:46 PM   #42
BLACK10
BLACK10's Avatar
HEADERS, CAI, NIGHTFURY CAM
