SDTW Custom Wheels & Tires
Old 05-13-2013, 10:04 PM   #1
NOT URSS
NOT URSS's Avatar
Drives: 2010 2SS/RS Camaro
Send a message via AIM to NOT URSS
l99 to ls3 conversion question
Did a search, but did not find the answer I was looking for.
I am doing the L99 to LS3 conversion and I purchased the new cam position sensor and the new cam position sensor harness. But looking at my factory harness female side is a 5 terminal connector and the new harness connector is 3 terminal which wont plug in. I'm guessing this has to be modified or did i buy the wrong part? Thanks so much
Matt
632RWHP/556RWTQ
NOT URSS is offline   Reply With Quote
Old 05-14-2013, 03:33 AM   #2
Kiwi_Camaro_2010
Kiwi_Camaro_2010's Avatar
Drives: Camaro 2SS/RS 2010 L99
I'm not sure what everyone else did, but I used original harness minus the plug for variable cam timing as I used 3 bolt cam, but I used the 3 terminal bracket to hold the 5 pin plug to keep it all tidy.
Camaro 2SS/RS 2010 / L99 / Whipple SC /Dynatech Headers & Catts (gutted), ID 850 injectors, ZL1 fuel pump +BAP & ADM pump controller, ZR1 3Bar MAP, Dual Elite Catch Cans, 91 octane ,Eibach sway bar kit , Driveshaft loop, oil cooler delete, ADM dual gauges (AFR/Boost) LC1 wideband controller, D/D, ARP stud kit ,Callies forged slayer crank 3.622", callies ultra rods, wiseco forged pistons, L99-LS3, rollmaster double row steel timing set & comps cam timing cover,blower cam 630/660 lift,3/8 pushrods, pac gear 8deg, yella terra ultra lites. LS9 head gaskets. Texas speed custom oil pump. Asm by me.
Kiwi_Camaro_2010 is offline   Reply With Quote
Old 05-14-2013, 05:36 AM   #3
NOT URSS
NOT URSS's Avatar
Thanks for the reply, still a little confused how u got the factory 5 terminal connector to plug into that 3 terminal connector ... From the looks of that picture looks like the 3 terminal connector on the bottom
632RWHP/556RWTQ
Old 05-14-2013, 05:44 AM   #4
Kiwi_Camaro_2010
Sorry, it is 3 terminal when i took pic, i don't have pic of 5 pin terminal, All I did was open retainer a little where bottom 3 pin was & squeezed in 5 pin minus 2 pins that were used for variable cam timing as I did not want to butcher main loom.
Old 05-14-2013, 08:04 AM   #5
Alvin@PCMofNC
Drives: 2010 IOM RSS
We normally cut a little spacer for the L99 Cam/Harness bracket and reuse it on the new setup. We normally also de-pin the wiring for the cam phaser just to clean it up a bit.
Alvin@PCMofNC is offline   Reply With Quote
Old 05-20-2013, 01:29 AM   #6
redredrage
redredrage's Avatar
Drives: 2010 Camaro SS manual all stock
Don't know why you would put a 454 in
redredrage is offline   Reply With Quote
Old 05-20-2013, 06:18 AM   #7
meshamey
Meshamey
meshamey's Avatar
Drives: 2011 Camaro 2SS / 2014 Camaro ZL1
meshamey is offline   Reply With Quote
