Solo Performance
Old 05-14-2013, 12:43 PM   #1
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
A6 and M6 in the ZL1, are they different than the SS?
I've been searching here and on the web for specs, can't find any. Are the transmissions in the ZL1 beefed up at all over the SS ones. If so, how?
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 05-14-2013, 12:47 PM   #2
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
I think the 6l90e is in the zl1 it is beefed up. the 6l80e is in the ss.
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 05-14-2013, 01:15 PM   #3
hognutz
hognutz's Avatar
Drives: 2013 ZL1
they are both different
M6 has a 550lb torque rating in the ZL1.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 05-14-2013, 01:24 PM   #4
willhe64
willhe64's Avatar
Does anyone know what the differences are?
Old 05-14-2013, 01:33 PM   #5
ShnOmac
ShnOmac's Avatar
I personally don't know what the differences are but I found this.... I make no guarantee this info is correct.
"The 6L90 transmission is slightly longer and taller than a comparable configuration 6L80 due to it's beefier internals. GM states, ". It is a heavy-duty version of the 6L80 six-speed automatic, with a strengthened input gearset which has two additional pinion gears for six total, and a strengthened output gearset, that uses wider gears than the 6L80. The 6L90 flexibilty extends to the clutches where the 6L90 has one more clutch plate than the 6L80 in each clutch for heavy duty applications."
http://www.tbssowners.com/forums/arc...p/t-59446.html
ShnOmac is offline   Reply With Quote
Old 05-14-2013, 02:15 PM   #6
SRT8Tech
2013 Super Bee
SRT8Tech's Avatar
Drives: 2013 Super Bee
How strong is the A6 and driveline in the ZL1. Does anything really need to be upgraded if you start getting into the 700+ RWHP range?
2007 Procharged SRT8 Charger..........SOLD
2010 Mopar 10 Challenger.................SOLD
2010 R/T Classic Challenger...............SOLD
2011 392 Challenger.........................SOLD
2012 mid 10 second 1/4 mile GT500.... SOLD
Current ride 100% stock 2013 Plum SuperBee............best of 12.407 @ 114.28 for now.
Tune, CAI and Drag radials. Best of 12.00 @ 115.74
SRT8Tech is offline   Reply With Quote
Old 05-15-2013, 07:43 AM   #7
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
thats it for torque? so pretty much with any power adders on the manual you will require a clutch? i thought the car camewith 560 torque?
joes407 is offline   Reply With Quote
Old 05-15-2013, 12:51 PM   #8
hognutz
hognutz's Avatar
Drives: 2013 ZL1
that's not the clutch that the tremec's torque rating. Tremec does not make the clutch.
both these transsmissions are reated at ~550lbs torque for a passenger car. they both seem to have good margin though as I don't see many failures.
clutches seem to be good to 700lbs or so. after that its a crap shoot I am sure.
I have seen ten seconds passes without failure.
for example the GT500's gearbox is rated at 650lbs and comes with 630lbs. they seem to beholding well though. 9 second passes on the stock.
I have had a syncro fail in a tremec but I have had good luck with strength to date.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 05-15-2013, 07:56 PM   #9
The Baron
The Baron's Avatar
Drives: 2013 zl1
ok, the 6l90s in the zl is basically the same as the 80.. the diff is it has one more clutch pack per gear.. they are a little longer because of it. the trans life is 100% dependent on the tuneup.. you can eat a 6 speed gm auto behind a stock motor with a incompotent tuner behind the keyboard... the 90 has shown to be a very good unit.. the 80, eh, not so much.. i have been dealing with these 6 speed autos since 07.. my vette was one of RPMS test cars for 6l80 stuff... they stopped building them for the average customer because Rodney (owner) could not trust his trans going out and then getting givin to just any tuner to blow it up and make him look bad....alot of cts-v guys have went into the bottom 10s on stock trans... the biggest problem is the line pressure and the fact if you stall them you cant jack it up enough to compinsate for a smaller converter and the shift timing most guys end up trying to make to short... the newest tunes that GM uses in the latest trans are really good.. in 07, they were JUNK.. the solinoids are MUCH better in the new trans also...each gear has its own. 1-2-3 clutches are on one shaft and 4-5-6 are on another... the 4-5-6 clutches are TINY little thinigs that give up easy.
I fought with my 80 for years and told myself that if the trans in the zl1 gets finicky it is going on a shelf.. being a camaro we have such a great option to just put a 4l80 in them it is silly to fight with the 6 speed. the vettes are diff and require MAJOR cutting and changes to get that trans to work while hese only require a DS and few minor changes...
that being said, the fastest zls (9 sec cars) are doing ok with the current 6l90s...my honest recomendation after having fought with them.. leave the stock converter in it.. it will live a long time..
hope this helps
2011 cts-v coupe (pinky) wifes car.. ls9 cam c.a.i. 11.44
2007 corvette vert ..retired..
2013 zl1 stock blower stock ci 20" wheels 10.36 135...so far..
The Baron is offline   Reply With Quote
