JUICEDMOTORSPORTS
Old 05-14-2013, 03:04 PM   #1
Chrisco22
Chrisco22's Avatar
Drives: 2011 Chevy Camaro LS
VMAX BLACK ICE IS HERE, IS THIS RIGHT?
Just opened the package from RX and all i got was the black ice, is that all im suppose to get? I was expecting bolts as well as instructions to install? Im pretty disappointed, looking for help
2011 Camaro LS: [Rally Yellow] [22" Status Rims] [BBK Long Tube Headers w/ High Flow Cats] [Trifecta Tune] [K&N CAI] [Blacked out Bow Ties and Tail Lights] [15% Tint] [MAC Mufflers] [Rear Cat Delete] [Vmax Black Ice]
Chrisco22 is offline   Reply With Quote
Old 05-14-2013, 03:05 PM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Nope, I think that's all there is to it. If you buy directly from RX, you don't get extra bolts or anything. I know Ivan@Southwest Speed will throw in extra bolts. The extra bolts aren't needed but they are nice to have. And no, you don't get instructions either.
Old 05-14-2013, 03:06 PM   #3
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
the stock bolts should fit back on with just the isolator. it is interesting that it didn't come with instructions.
Old 05-14-2013, 03:07 PM   #4
PoorMansCamaro
Drives: Really Slow
I could have sworn I got directions back when I got them, when they were fairly new on the market.
Old 05-14-2013, 03:12 PM   #5
Chrisco22
Chrisco22's Avatar
Yeah, i mean im not an idiot, but im pretty sure instructions would help. Anyone know where i can get instructions? Hopefully the gains are noticable with this, cuz at the moment im not to happy with it. It took a month to arrive as well.
Old 05-14-2013, 03:13 PM   #6
Ivan @ Southwest Speed
Lotta love...thanks for the shout out. We try to keep it real for folks and include stuff to make it a little easier.
They should come with instructions and bolts. The bolts are an interesting deal. I've installed a few without needing them but most of the cars do need them. Safer, makes it less susceptible to stripping out the lower IM, just smarter IMHO.
Shoot me a PM with your email...I'll email you the instructions.
Old 05-14-2013, 03:15 PM   #7
PoorMansCamaro
Drives: Really Slow
Here are step by step instructions with pics for both insulator and IM with port matching guide:
Step 1:
Remove air coupler:
Unplug vac hoses:
un plug TB harness:
remove to 13mm bolts from rear of IM (these are not resused with the isolator)
and the rest (make sure to get the rear IM bolt tha is somewhat hidden)
Lift plenum cover off and make note of this sealing spacer. It is reused:
remove bolt from front brace (this is also not reused)
remove intake manifold making sure rear most bolt is held up to clear...when reinstalling bolt needs to be in IM before fitting back under cowl)
Reuse OEM gasket, but cut the tabs that hold these 2 nobs on and remove:
The next steps are optional port matching done with a round abrasive bit on a die grinder but can be done w/a dremel as well. The idea is NOT to go deep or alter the port shape any more than tapering and blending to match:
With gasket in place you can see the transition lip....trace OEM gasket openings with a sharpie marker:
Remove gasket and tape over all ports except the one you are matchng. Stuff a paper towel wadded up into the port to keep debris out of the cylinder and use a shop vac to suck up flakes as you work:
Again!! Only blend and open to the sharpie line. You want no flow disrupting transition, but do NOT want to go ery deep into the port:
Should look like this when complete:
and with the gasket installed:
with Black Ice-olator installed....see the nice transition now?
Spread a small bead of Permatex Right stuff (or RTV) around each port making sure to not over do it. You dont want it squeezing into the port and causing a flow disruption)
Reinstall all in reverse and make sure to tighten the rear most and front most bolts (they are slightly shorter than the main center ones) first tobegin comprssing the gasket. This will allow the center ones to start properly:
Old 05-14-2013, 04:26 PM   #8
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
You reuse the stock hardware and VMAX does not include instructions. I believe we print some off and put them in with the one's we have in stock.
Old 05-14-2013, 05:07 PM   #9
Chrisco22
Chrisco22's Avatar
Should i feel a relative difference with this installed?
Old 05-14-2013, 05:08 PM   #10
Apex Motorsports
Yes. You will definitely notice it.
Old 05-14-2013, 09:13 PM   #11
RubyCamaro
Jan
RubyCamaro's Avatar
Oh Hell Yeah, you will notice!
Old 05-14-2013, 10:27 PM   #12
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
Thanks PoorMan, subscribing just for your post!
ChadG is offline   Reply With Quote
Old 05-14-2013, 10:51 PM   #13
hawkfe
hawkfe's Avatar
Drives: 2014 Stingray 3LT
Question: With the ICEolator and Plenum Spacer does the engine cover fit back on?
hawkfe is offline   Reply With Quote
Old 05-14-2013, 11:03 PM   #14
bandier
Got mine!
bandier's Avatar
Drives: 2010 Camaro 2LT - Yellow w/ Stripes
Now that's just good business !!!
bandier is offline   Reply With Quote
