Solo Performance
Old 05-15-2013, 01:38 PM   #15
Cyber Gray
Wind Rider
Cyber Gray's Avatar
Drives: Black 2SS/RS 14; Jeep 5.7 GC 15
Originally Posted by Chrisco22 View Post
Should i feel a relative difference with this installed?
25mm isolator is the best V6 mod in the market.
Im not Gray any more !!
Cyber Gray is offline   Reply With Quote
Old 05-15-2013, 02:02 PM   #16
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Originally Posted by hawkfe View Post
Question: With the ICEolator and Plenum Spacer does the engine cover fit back on?
I know i have seen people re-install it with just the Iceolator but i haven't seen many install it with the Plenum cover. You probably will need to extend the oil filler neck and the engine cover stud in order to re-install the cover though
Proud owner of litho #179 Click Picture for Build Thread
Old 05-15-2013, 05:50 PM   #17
SC2150
All instructions are on our website: www.RevXtreme.com
Lower left corner, under "information"
No need for longer bolts unless getting the plenum spacer as well, just follow the instructions.
Old 05-29-2013, 05:38 PM   #18
spyder
Drives: 2010 V6 | M6
I'm not a mechanic but I feel like I can do the install of the iceolator. I know I need a flex head 13mm ratchet wrench for the rear bolts. What size or sizes should torque wrench be? Are all the bolts 13mm?
BBK 304 LT headers w/ coating | CAI Inc Intake w/ scoop | VMax Ice-olator | MRT v2 | Elite catch can | Trifecta Tune | Eagle halos | 20" Textured Black Forgestar F14s
- They call it the black panther.
2010 Camaro LLT (sold)
2008 Yamaha WR250X
2011 Nissan Armada 4WD Platinum
spyder is offline   Reply With Quote
Old 05-29-2013, 06:10 PM   #19
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
13 mm bolts for all the ones on the top. 18 ft lbs of TQ when installing them. Be sure to do it while the engine is cold.
Old 05-29-2013, 09:31 PM   #20
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
So would you consider buying a torque wrench for this install mandatory?
Would a $20 deflection bar torque wrench be good enough?
ChadG is offline   Reply With Quote
Old 05-29-2013, 09:52 PM   #21
rtcat600man
Yes, breaking that bolt off in the head would be bad.
No, I would invest in a good torque wrench. Every mechanic should have one. Can be used for every bolt on the car. Including the lug nuts. I use mine often. Every time I change to my drag radials, rotate my tires, etc.
Old 05-29-2013, 11:57 PM   #22
ChadG
ChadG's Avatar
Mind sending me a link to one that is rtcat600man approved?
Old 05-30-2013, 10:39 AM   #23
rtcat600man
I didn't know Sears carried so many differant styles.
http://www.sears.com/search=torque+w...e=CAT_REC_PRED
Old 05-30-2013, 11:10 AM   #24
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
Question regarding the DIY.
When port matching. Isn't it a bad this to have the dust from the shaving fall into the hole ?
Old 05-30-2013, 01:13 PM   #25
LIM3
LIM3's Avatar
Drives: SGM
Oh and what are the benefits of port matching ?
Old 05-30-2013, 01:15 PM   #26
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
hmmm..anyone just try flaring the port w/o the isolator..any difference?
Old 05-30-2013, 08:31 PM   #27
pgustavson
Stop writing "vert", ffs!
pgustavson's Avatar
Drives: 2011 2LT Convertible
Gasket-matching has been said to be worth a few HP, but isn't entirely necessary if a stock intake manifold is being used, since the IM ports are same size as the head ports and both are smaller than the gasket openings. If the IM has been ported and its ports match the gasket opening, then the stock head ports leave a sharp corner sticking into the flow. It is recommended to blend that in to match the gasket opening. It isn't a lot of material that gets removed.
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator
pgustavson is offline   Reply With Quote
Old 05-30-2013, 09:02 PM   #28
LIM3
LIM3's Avatar
Drives: SGM
That's great to know !! If I decide to do this my self what should I do to prevent the dust and residue from falling in
