third_shift studios
Old 05-14-2013, 08:48 PM   #1
white1LE
white1LE's Avatar
Drives: 2013 Camaro ZL1
Help! PCM crashed
I oerdered the 415 Brawler package from Jannetty Racing and included is the SCT tuner, that connects to my android via blutooth. Had problems connecting last night then called Jannetty this am for help. Turns out it needed updates so i did that today and got it to connect tonight and began to upload til it got to 5% then brought up a failure code. Now my stabilitrac and every other light is on in the dash, AND when i turn the key it won't even turn the engine over. I've been building engines and working with tuning for 15 years and this usual isn't good when it stops in the middle of a download. Any suggestions would be greatly appreciated. I did check codes with diognostic side of the tuner and pulled 0 codes.
white1LE is offline   Reply With Quote
Old 05-14-2013, 10:26 PM   #2
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2014 Summit White 2SS/RS 1LE
Have you tried uplaoding again, at this point if the pcm is toast it cant hurt to try a few more times
2018 ZL1 1LE on order, Summit White, PDR, NAV
**FOR SALE**http://www.camaro5.com/forums/showthread.php?t=5003112014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Elite Gen2 CC, ZL1 splash guards, ZL1 pedals, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's on HoosierStone Tires, Previous Car: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98 FS
ICTsccaCamaro is offline   Reply With Quote
Old 05-14-2013, 10:40 PM   #3
white1LE
white1LE's Avatar
I have but it goes into a generic tuning process where i have to pick the correct PCM and trans.
Old 05-15-2013, 06:07 AM   #4
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Have you tried to return it to stock? You should of backed up the stock tune.
Scott@Bjorn3D is offline   Reply With Quote
Old 05-15-2013, 01:53 PM   #5
MikeOD
Drives: 2010 M6 2SS
Try to just let the PCM sit without power for a half hour...maybe even unhook the battery.
It's VERY difficult to brick an E38. I don't know if those tuners overwrite the entire flash or just the data tables like actual laptop software does, but again like I said, it's very very hard to brick one...try that and then see if it will take a flash.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 05-15-2013, 03:54 PM   #6
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Yep. I think pulling power and reflashing has worked in every instance I've ever read where this happened.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 05-15-2013, 06:00 PM   #7
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Seen this happen. Its not bricked it Needs a total re-flash by either the dealer or a tuning company that has the same/similar equipment. Your system won't do it. I think it goes into some sort of security mode from what I saw.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 05-15-2013, 07:18 PM   #8
white1LE
white1LE's Avatar
Thanks for the help guys! I unhooked the negative battery last night and hooked it up again this am, fired right up and no lights on. TSX wants the tuner so they can reset it then return it to start over.
Old 05-15-2013, 08:00 PM   #9
thahemp
Geek
thahemp's Avatar
Glad you made it out unscathed.
x = ~x
Old 05-16-2013, 09:47 AM   #10
NickJRE
NickJRE's Avatar
Drives: Nothing Fun.
Glad SCT is getting you straightened out, I knew they would. Like I said on the phone yesterday keep me posted
NickJRE is offline   Reply With Quote
Old 05-16-2013, 10:25 PM   #11
white1LE
white1LE's Avatar
Thanks Nick! Called your shop today for a quote on a supercharger package. Looking forward to doing business with you again. It's great to call a business and always get someone on the phone to talk to.
Old 05-17-2013, 08:28 AM   #12
NickJRE
NickJRE's Avatar
