Solo Performance
Old 05-14-2013, 09:54 PM   #1
jnikkila
jnikkila's Avatar
Drives: LS/LLT
Changed to Summer Tires, threw a CEL
Changed to some SS rims with Nittos today that I just picked up and after 30ish miles got a Check Engine Right before a Service Tire Pressure System...Is this normal? I expected the Tire Light but not the CEL
jnikkila is offline   Reply With Quote
Old 05-14-2013, 10:37 PM   #2
jnikkila
jnikkila's Avatar
Drives: LS/LLT
BUMP
Codes showing are;
P0703 - Brake Switch Circuit Malfunction
P0726 - Fuel Pump A Control Circuit/Open
Also just switched to a used locking gas cap...
Old 05-14-2013, 10:47 PM   #3
Rob21sf
Rob21sf's Avatar
Drives: Black 2011 Camaro LLT
I've never heard of changing tires throwing out a CEL. Maybe its just a coincidence that it came on when it did. Did you do anything else recently to your car?
Rob21sf is offline   Reply With Quote
Old 05-14-2013, 10:59 PM   #4
jnikkila
jnikkila's Avatar
Drives: LS/LLT
Just reinstalled mace plenum spacer and manifold spacer like 200 miles ago. This morning put on a used locking gas cap i got from a friend...drove about 20-30 miles with no problem and most recently tonight changed the wheels out. Drove 20 miles fine then threw cel and less than a quarter mile later popped up with tire pressure system lights. Drives fine. Idles fine. No problems that i can tell. Just CEL
Old 05-15-2013, 09:41 AM   #5
blkngldbabe
Barossa's handler
blkngldbabe's Avatar
Drives: 2LT/RS RJT
My guess is the gas cap.
SLP's GTA Master Specialty Vehicle and Master Parts Dealer
blkngldbabe is offline   Reply With Quote
Old 05-15-2013, 11:52 AM   #6
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Old 05-15-2013, 11:53 AM   #7
jnikkila
jnikkila's Avatar
Drives: LS/LLT
Still leaves the brake switch circuit malfunction...
Old 05-15-2013, 12:46 PM   #8
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Maybe when the tires were being put on it may of hit something.
Can't_C_Me is offline   Reply With Quote
Old 05-15-2013, 01:36 PM   #9
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
If the tech who swapped the wheels moved your TPMS sensors around (say the R.rear wheel sensor is now on a front wheel)you'll need to re-set the computer. Details in the owners manual.
After that, I'd put your OE gas cap back on and try a reset on the CEL's. A battery disconnect will do it if you don't have a OBD reader.
If your tire pressure is good and your Service Tire warning comes back, they may have damaged or just incorrectly installed the wheel sensors.
And that Brake Sensor Circuit may be the result of rough or inept swap as well.
Good luck!
