Emblempros
Old 05-15-2013, 11:51 AM   #1
SSlacker
SSlacker's Avatar
Drives: 2012 2SS/RS
Tuning required?
2012 2SS L99
Deleted mufflers
Installed CAI
Going to install air scoop/washer relocate this weekend.
Running 93 octane
Did fuse pull
After installing the CAI, totally changed the sound and can fell the difference in overall get up and go...
But, sometimes when I get on it there is serious lag in throttle response, Like its choking down.
Do I need a tune?
Suggestions?
SSlacker is offline   Reply With Quote
Old 05-15-2013, 12:33 PM   #2
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
A ported throttle body should clean that up some.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 05-15-2013, 12:37 PM   #3
family man
Drives: .
And the active fuel management could be causing it to. Check out this thread http://www.camaro5.com/forums/showthread.php?t=283175
family man is offline   Reply With Quote
Old 05-15-2013, 01:10 PM   #4
SSlacker
SSlacker's Avatar
Drives: 2012 2SS/RS
Thanks.
I didn't think about the AFM.
AFM is very annoying.
Old 05-15-2013, 07:35 PM   #5
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
A good custom calibration will sure wake it up, and it will be much more responsive as well. Let me know if I can help you in any way or if you have any questions.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
shop.gwatneyperformance.com ryan@gogwatney.com josh@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 05-15-2013, 09:09 PM   #6
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Originally Posted by SSlacker View Post
2012 2SS L99
Deleted mufflers
Installed CAI
Running 93 octane
Did fuse pull
Do I need a tune?
Suggestions?
I have only seen a few people with tunes from Rhino so far... all have been very happy. What I have seen out of Rhino in the past has been mostly next level knowledge (stuff you wouldn't know otherwise essentially) about automatic transmissions and engine electronics. If you're not worried about warranty get the tune. I didn't notice much from the ported throttle body.
Exhibit A. First pic is pre-tune LTFT vs. RPM. Second pic is post-tune LTFT vs. RPM. This is the kind of "tuning" that makes your car feel like it is supposed to. Look how out of whack and random the trims are on the stock tune. Right there in the middle it gets faked out by me letting off the gas due to loss of traction , then when I get back on it... the trims are just all over the place. Mine used to do a weird misfire if I punched it with traction control on. Example after example of your car's brain not being able to cope with certain scenarios.
::EDIT:: If I would have highlighted knock retard, you would see that the stock tune was full of it. It was hard to make sense of. Everything just seemed random.
My mods pre-tune were intake + ported throttle body + catback.
My mods post-tune were intake + ported throttle body + headers + catback.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 05-16-2013, 07:52 AM   #7
meshamey
Meshamey
meshamey's Avatar
Drives: 2011 Camaro 2SS / 2014 Camaro ZL1
meshamey is offline   Reply With Quote
Old 05-16-2013, 08:50 AM   #8
thahemp
Geek
thahemp's Avatar
I have a feeling I'm reading too much into those previous graphs. Someone will straighten me out .
Maybe these would be more relevant to what the OP is looking for. Throttle position vs. RPM.
Pre-tune.
Post-tune
x = ~x
Old 05-16-2013, 09:29 AM   #9
Birm
Birm's Avatar
Drives: Florida Speed & Power
I would wait until you are ready to add power adders.. headers/cam/sc whatever your poison... Tune is not needed at this level... What you have are "complimentary" mods, not really standalone.
If you care less about your warranty then absolutely, tune it and you will see much better performance top to bottom (shifting/throttle response/power etc..).
As someone else had mentioned, a "Ported Throttle Body" would assist in cleaning up your throttle response some and for the money its worth it. Let me know if you are interested as we have some on the shelf ready to go. Or just go to the website in my sig
If you are interested in a tune though hit me up, we have one of the best tuners around-Matt Sorian (Matt@FSP).
Birm is offline   Reply With Quote
Old 05-17-2013, 11:05 AM   #10
Rhino79
Rhino79's Avatar
Next Friday I will have, as will other members, some before and after tune dyno numbers. I have about 4-5 cars Im travelling to do and Ill be sure to post some numbers and mods for each setup. No better way to show the value of a good calibration than to post before and after graphs. Some vehicles already have some calibration work done, which will be even better to show the difference between different calibrations.
Tuning is not always a must, but even in stock form, there is power to be had. As you mod up, even with just bolt ons, the gains will grow more.
Old 05-17-2013, 12:20 PM   #11
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1951 Mercury
Not uncommon for an L99 to get 1-2 tenths improvement in ET just from a tune. Plus you can turn off AFM, and you can speed up the paddle shifter response time. I'd suggest Rhino (Ryan), he's been L99'n for a long time and knows what he's doing.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 05-17-2013, 12:28 PM   #12
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Thanks.
It becomes more evident when you change the exhaust tone.
Mechanically, the car has to think about meeting thresholds, getting out of AFM, and fining the proper gear is what is causing your lag time.
After calibration, the car responds much better and if done properly with a wideband, it will hit your commanded target AFR and not knock.
Phil
www.TampaTuning.com
Tampa Tuning is offline   Reply With Quote
Old 05-21-2013, 11:24 AM   #13
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Attachment 510688
Attachment 510689
Your Target LTFT are 1.0 + or - .03
In the first on your too lean
In the second one your too rich.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 05-21-2013, 12:30 PM   #14
thahemp
Geek
thahemp's Avatar
Thanks Ted. Every new day of reading makes me look back at posts just a few days ago and feel silly for posting such nonsense. Even the stupid posts get me thinking and researching again though.
Should I have reset my trims and taken longer drives for you? Looking back I think I could have done a much better job of datalogging. Do you just know from experience (seeing a ton of roughly the same car/mods) about how much to bump things by looking at changes in LTFTs between datalogs?
I still need to do a log of the tune it's running now. I think I'll reset my LTFTs and take a longer drive this time. I need to start keeping that laptop in my car.
x = ~x
