05-15-2013, 02:38 PM | #1 |
Drives: 2000 Camaro SS 2013 ZL1 Camaro Join Date: Jul 2012
Rear end making a winding noise and GM bulletin regarding it.
I dont drive my car as often as I want to and after 7 months I have about 4300 miles. I took it in to the dealer to have the oil changed and I mentioned the winding noise in the rear end when I am backing up out of my driveway and turning at the same time. I can hear it going forward and turning as well. I know for sure the tires are not rubbing. The dealer told me he had to order parts that there was a bulletin. Anyone heard of this? I asked him to see the copy of the bulletin, so I can look for myself.
05-15-2013, 02:46 PM | #2 |
Drives: 13 ZL1 SIM, 99 Z28 Black Join Date: Feb 2013
That might be the bulletin for the SS where they put in new seals and fluid. You don't need that done on the ZL1. It is posted in here somewhere if you do a search.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
05-15-2013, 02:55 PM | #3 |
My car makes the same noise. Please post when you find out someything!
05-15-2013, 03:05 PM | #4 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
Take it to the dealer they may need to flush the rearend. Mine did the same, they flushed it, refilled it and it went away. Many other people have had the sane problem. They figure some of the lashing compound is responsible.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
05-15-2013, 03:39 PM | #5 |
I thought it may be for the SS also that's why I wanted to see the bulletin and post this. I really don't want them tearing into my rear end.
05-15-2013, 03:46 PM | #6 |
HAMMER PILOT
That bulletin is not for the ZL1, they are different, it has been confirmed here on other threads.
05-15-2013, 03:55 PM | #7 |
HAMMER PILOT
I had mine to the Dealer twice, the first time they replaces the ring and pinion. They said the backlash was off, it was quiet for awhile and the noise came back. Next time they flushed it and refilled and it has been quiet since. Don't know if this is the universal fix but it worked for me. Below is the bulletin.
Subject:Rear Axle Chatter Type Noise on Low Speed Turns (Excluding ZL1) Models:2010-2012 Chevrolet Camaro (Excluding ZL1) Equipped with Limited-Slip Differential (RPO G80) Attention:For 2010 and 2011 vehicles built prior to August 25, 2010, if the chatter noise you are experiencing occurs only in Reverse while making a turn, please review the latest version of PIC5424. This PI is being revised to add an Attention statement and update the Recommendation/Instructions. Please discard PI0137B.The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.Condition/Concern Some customers may comment on a chatter-type noise from the rear of the vehicle while making low speed turns. This condition may be caused by a slip/stick of the posi-traction clutch plates. As the plates slip and stick, a jumping or jerking feel occurs, accompanied by a chatter noise. Recommendation/Instructions Caution: The rear axle seals must be replaced. The original seals are not compatible with the new fluid. Replace both rear axle shaft seals with GM P/N 22798805 and drain/refill the rear differential with new fluid, GM P/N 88862624 (in Canada, use P/N 88862625). Refer to the Rear Axle Shaft Seal and Differential Oil Replacement procedures in SI. This fluid includes a limited-slip additive (friction modifier) already added. DO NOT add any limited-slip additive (friction modifier). Important: Please advise the customer that once the differential fluid has been changed, it may take as long as 805 km (500 miles) for the lubricant to fully penetrate the limited slip clutch plates. During this period some chatter may still be felt on initial startup while making slow turns until the rear differential fluid warms up. Note: DO NOT re-use the wheel drive shaft nut. Replace with NEW only.
05-15-2013, 06:39 PM | #8 | |
05-15-2013, 07:41 PM | #9 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Sigh! Here we go again. This is all you need to fix it.
Bryan 2018 ZL1 M6
05-15-2013, 09:12 PM | #10 |
Drives: '12 SIM ZL1, 1 of 49 Join Date: Sep 2011
Put the whole bottle in!
Under Hood - Painted strut bar ends w/custom Polished Stainless mounting hardware, E2 CC, RotoFab CAI, ZL1 underhood decal, Amsoil oil, Black billet strut covers, Metco pulleys, intercooler reservoir, JRE 75 RWHP package.
Chassis - Hawk ceramic brake pads, ZL1 wheel decals, Amsoil fluids Interior - A pillar gauge pod w/Aeroforce Interceptor gauges, Polished ZL1 speaker rings, ZL1 mats and console lid, Custom GPS mount Exterior - 3M clear bra, LED driving lights, PIAA Plasma Ion yellow fog lights, Window tint, CF bowties, Technostalgia sequential tail lights |
05-15-2013, 09:41 PM | #11 |
Drives: Black ZL1 Join Date: Apr 2013
Not winding, but chatter or what ever, I have a knock when I would make a tight turn at low speeds, like backing out of the driveway. I took it to the dealer, this has been a while and since they hadn't worked on a ZL1 yet they got on the hotline. What they came up with, they changed the fluid, was that it was normal until the rear end got warm. So since then I have noticed that once I make it a 1/8 or 1/4 mile down the road it doesn't do it anymore.
I don't know.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
05-15-2013, 09:56 PM | #12 |
Mid-Florida Camaro Club
Drives: 2019 ZL1 on Order Join Date: Jan 2011
Had this issue on my ZL1 - they replaced the rear diff fluid, performed several figure 8s etc and the problem was gone.
That's all that they will need to do with yours too I would imagine
05-15-2013, 10:05 PM | #13 |
hauls ass not asses!
Drives: Synergy Green 1LT/RS Join Date: Feb 2011
I really don't want them tearing into my rear end.[/QUOTE]
That's what she said!
Got It! Got It! Got It! Everyone I know is dumbfounded by the QUALITY...way to go Chevy!
05-15-2013, 10:38 PM | #14 |
Drives: ZL1 #529 "El-Jefe" Join Date: Mar 2012
Thread Tools | |
