BeckyD @ James Martin Chevy
Old 05-16-2013, 01:20 AM   #15
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
What do you mean flush? Did you just drain it completely and put in new fluid, or did you flush it out with something?
2017 C7 GS - WGG, A8. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
Old 05-16-2013, 07:27 AM   #16
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
my dealer refused this repair for me because firstly by the time i get to dealer the rear is warmed up and doesnt make the noise for them and secondly because the damn service bulletin says not to do this fix on ZL-1. mine has been making this noise for 20k miles now and its worse on colder mornings
joes407 is offline   Reply With Quote
Old 05-16-2013, 07:55 AM   #17
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2013 ZL1 #2303
You need to go to a different dealer then!
Starling fixed mine without even a question - been fine ever since
Modern07 is offline   Reply With Quote
Old 05-16-2013, 08:05 AM   #18
OldScoolCamaro
Originally Posted by Al C. View Post
Not true.. If you use the recommended rear diff fluid for the ZL1, it already has the lim slip in it.. I had the same issue.. I bought 3Qt and did the flush in my garage, problem fixed..
Sold over the counter at Chevy parts, the 1 qt. bottle of synthetic gear lube with friction inhibitor is the factory replacement lube. I changed my rear axle fluid last week. 1,600 miles. I had many of the same, normal noise issues as most others associated with the ZL1. I diagnosed mine as normal break in with a HD posi rear. Both magnetic plugs had a yellow base accumulation on them, then layered with the dark grey build up of contamination totalling approx. 1/2" thick. Also there were several small slivers of metal. I highly recommend everyone change the rear axle fluid. I will post the GM P/N later.
Old 05-16-2013, 08:07 AM   #19
The Stig
knows 2 facts about ducks
The Stig's Avatar
Originally Posted by OldScoolCamaro View Post
True. Sold over the counter at Chevy parts, the 1 qt. bottle of synthetic gear lube with friction inhibitor is the factory replacement lube. I changed my rear axle fluid last week. 1,600 miles. I had many of the same, normal noise issues as most others associated with the ZL1. I diagnosed mine as normal break in with a HD posi rear. Both magnetic plugs had a yellow base accumulation on them, then layered with the dark grey build up of contamination totqlling approx. 1/2" thick. Also there were several small slivers of metal. I highly recommend everyone change the rear axle fluid. I will post the GM P/N later.
I know I have an SS, but I saw pretty much the same gunk, crap, etc. in my fluid when I changed it at 1,500.
Click to view my build thread
Old 05-16-2013, 08:22 AM   #20
Rizzo
Drives: 2012 Camaro ZL-1 SIM
Originally Posted by Sven59 View Post
That bulletin is not for the ZL1, they are different, it has been confirmed here on other threads.
I had the same issue on my ZL1. The dealership still honored the TSB and changed the fluid and seals. The noise has gone away.
I have a feeling that the TSB will need to be expanded to include the ZL1
Rizzo is offline   Reply With Quote
Old 05-16-2013, 08:57 AM   #21
PNYSLAR
Summit White 2012 ZL1 M6
PNYSLAR's Avatar
Drives: 2010 BLACK 2SS/RS M6 Delvd 8/24/9
Originally Posted by Bowtie724 View Post
I dont drive my car as often as I want to and after 7 months I have about 4300 miles. I took it in to the dealer to have the oil changed and I mentioned the winding noise in the rear end when I am backing up out of my driveway and turning at the same time. I can hear it going forward and turning as well. I know for sure the tires are not rubbing. The dealer told me he had to order parts that there was a bulletin. Anyone heard of this? I asked him to see the copy of the bulletin, so I can look for myself.
Yes I had the same thing happen to me @5k on my 2012 ZL1. The parts they had to order for mine were seals. They had none anywhere close to the dealership and took over a week for them to arrive. Seems the 2012's have the same issue when they reach the magical reading of @5k on the odometer.
2012 Summit White ZL1 Manual 6sp Blk 10 spoke, "Thanks Champion Chevrolet" delivered 6/9/2012 #1588
PNYSLAR is offline   Reply With Quote
Old 05-16-2013, 09:23 AM   #22
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
I changed mine too. It comes back. Put some additive in and it will be silent.
Bryan 695 SAE RWHP 2012 ZL1 9.55 pulley custom cam and Kooks headers, 2002 Z06 447 RWHP, 2006 Trailblazer SS, 1995 S/C Vortech Trans Am 570 RWHP(for sale)
ZO6 Bryan is offline   Reply With Quote
Old 05-16-2013, 10:18 AM   #23
Al C.
Al C.'s Avatar
Drives: ZL1 #529 "El-Jefe"
Sorry bad choice of vocabulary... Drain and refill with new fluid.
If you have to add the limited slip inhibitor, you are not using the correct fluid..
The ZL1 has a specific fluid, not like the SS, that has the inhibitor already in it and it is advised NOT to add any additional lim slip.
GM PART NUMBER: 88862624. My plugs looked like what u described when I drained the rear end and I agree fork out the $70-80 to change ur diff fluid.. If that doesn't work, which it will, take to the dealer..
.. If you filled with the fluid that has the inhibitor and added additional lim slip to it, not good. I'm sure it will have some "results" but definitely not advised.
Al C. is offline   Reply With Quote
Old 05-16-2013, 10:34 AM   #24
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Did this also fix the slight whinning noise that we get when lightly on the throttle at highway speed?
Yes!
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 05-16-2013, 11:54 AM   #25
ZO6 Bryan
ZO6 Bryan's Avatar
Who says that they aren't compatable? The ZL1 comes with SYTHETIC Limited Slip fluid. The SS comes with convetional limited slip fluid. There is nothing magic about the GM recommended fluid. Just stick to the synthetic fluid. The TSB for the SS has them replace the convetional LS fluid with the synthetic fluid. So there is no need to tear down the rear end to replace seals in the ZL1. This is not a new problem. Noise from clutchs in limited slip rear ends has been around since they were invented decades ago. If you had a 20 yr old car with limited slip then put the additive if its noisy. If your ZL1 is noisy do the same thing.
Old 05-16-2013, 12:37 PM   #26
Al C.
Al C.'s Avatar
This sums it up..
There is a downside to adding too much friction modifier. The diff clutch plates are what give the diff its limited slip ability. They are designed to grip to each other and pass torque to the tire with grip when one tire looses grip. When your fluid properties are not correct (too slippery), these clutch plates lose their friction with each other, thus the diff becomes more like an open diff.
While that might not be as much as factor on the street, you should at least recognize that adding too much modifier, while it won't hurt the diff, does cost you performance. The goal is to just have enough additive to prevent chatter and no more.
Old 05-16-2013, 01:13 PM   #27
HDRDTD
This sums it up..
OK, stupid question....
Does the friction modifier increase or reduce the friction of the clutch plates?
Old 05-16-2013, 02:03 PM   #28
Al C.
Al C.'s Avatar
Adding the modifier reduces friction, less friction to the plates reduces torque to the wheels there for "less" power. if you want to increase friction you add less modifier but then you get "stick slip" or chatter. So the modifier is just that, it's used to modify the coefficiency of the diff fluid to suite you application.
