SDTW Custom Wheels & Tires
Old 05-15-2013, 04:30 PM   #1
vegassam66
vegassam66's Avatar
Drives: 2012 Camaro 2SS / RS
Ready for the next round of mods
Here is what I have had done so far to date;
TVS 2300 supercharger
Rotofab CAI
TSP 2" LTH
3" Stainless works exhaust
A few other little tricks and a killer custom tune from Leading Edge Performance.
I was thinking of a stall converter and some stickier rear tires. Any recommendations out there. My dyno numbers are 502rwhp & 504 rwtq
Thanks in advance
vegassam66 is offline   Reply With Quote
Old 05-15-2013, 07:45 PM   #2
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
Your question is a little vague. What is you want to do ?
Mchlgrrsn is offline   Reply With Quote
Old 05-20-2013, 11:50 PM   #3
vegassam66
vegassam66's Avatar
The car has a ton of power, however it still doesn't launch very well. Trying to get the pasted to the seat off the line effect. Better tires because the P-zero's are all over the place under WOT
Old 05-21-2013, 08:15 AM   #4
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drag radials do hook pretty damn good. I was all over the place with pzeros. Drag radials are night and day. I like the MT. Nittos good as well.
Old 05-22-2013, 03:47 PM   #5
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 944 RWHP/787 RWTQ
If money is not too big of an issue then a good blower cam will pick up about 30 hp. Then I would slap a 4.11 gear in the rear and some drag radials, then your set!
F-1X, Cog Drive, ATI Super Pulley/Sprag restriction limited to 15-16 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Twin Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
?? second 1/4 mile
BiggFoot is offline   Reply With Quote
Old 05-22-2013, 06:38 PM   #6
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
you may want to start thinking about Drivetrian at this point.
Driveshaftshop is offline   Reply With Quote
Old 05-22-2013, 09:56 PM   #7
SPCBA
Drives: pleather and Chiclets
what do you drive your car on. lighter wheels and stickier tires seems a good direction as well as suspension.
SPCBA is offline   Reply With Quote
Old 05-23-2013, 01:16 PM   #8
amerimuscle
Drives: 2011 Camaro 1SS
http://www.camaro5.com/forums/showth...dle+blower+cam
^^^ mind boggling
amerimuscle is offline   Reply With Quote
Old 07-10-2013, 01:07 AM   #9
VEGASLSX1
Drives: Camaro RSSS
Converter Converter Converter!
M/T drag Radial done!!
VEGASLSX1 is offline   Reply With Quote
