HeadlightArmor
Old 05-16-2013, 12:26 PM   #1
Wollmank
Drives: 2014 Camaro 2SS/RS 1LE AGM
Bad engine knock? V6
Hello guys, I'm new to this posting thing I would appreciate any input on this subject. I have a 2012 2LT ( yeah it's a v6 whateves )
I got a Volant cold air intake and flowmaster axle back exhaust for my birthday, something that I would not of chosen, but my wife tried to surprise me.
I really like the sound, no drone, always getting asked if I have a turbo charger? Why I dunno... Anyways, before I installed these parts I had a little engine knock, no matter what gas station I used, when using 87 octane. After installed these to mods, The engine knock is getting worse, again I tried many different gas stations, I notice if I put 93 in the tank there is no engine knock at all. I tired 89 octane there is engine knock but not that bad, but it's there.
If these mods have no effect of engine knock, ( I'm at the dealership getting an oil change while tying this, I asked 2 different service advisors.)
Why do I get really bad engine knock using 87 when the car calls for it, everyone here at the dealership is telling me NOT to put 92 octane, it will hurt my engine. But if I put 87 octane (again many different gas stations, many different times testing this) why is my engine knocking? It's really embarrassing at every traffic light to give it a little gas, sounds horrible. Oh, I also noticed that sometimes, at a traffic light, only when engine has been running for at least 20 minutes, my idol drops below 500 for a few minutes and starts to give like a pulley squeak sound. Every time I bring my car to the dealership for them to check it out, it does not make the sound or drop below 500 rpm.
Thanks in advance... Keith
Wollmank is offline   Reply With Quote
Old 05-16-2013, 12:29 PM   #2
bw26ss
Banned
Drives: ss camaro
I hate to say this, but sounds like a timing chain issue
bw26ss is offline   Reply With Quote
Old 05-16-2013, 12:36 PM   #3
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
First of all, 92 octane won't hurt your engine. Period.
Check all the fittings for the CAI. It sounds like you have a leak. Not sure why the octane of the gas makes a difference, but if you had enough real engine knock for you to hear, you would also have a CEL and it would probably go into reduced power mode.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 05-16-2013, 12:41 PM   #4
Wollmank
Thank you for the response, as I said I'm here at the dealership getting an oil change, they said since I have 92 octane in it now they really can't test the issue, and for me to bring it back with 87 octane so they can test it correctly. I mentioned the timing chain comment to my service advisor and he says dont believe what I read on the Internet. ;-/
I don't believe these people here at the stealership for a second. ( I had the small leather part on my dash coming apart) they wanted to pull my windshield and replace the entire dash board) lol no I didn't let them, after reading a bunch of posts on here regarding the same thing I told my service advisor the it is a separate piece from the dash and gave him a part number, he looked at me like I had three heads.. I get many opinions before any actual work is done. Thanks!
Old 05-16-2013, 12:42 PM   #5
TheGhosty
TheGhosty's Avatar
Drives: '11 SW 1LT RS
I am not sure this is the issue but this is common on our cars. look into this^
TheGhosty is offline   Reply With Quote
Old 05-16-2013, 12:43 PM   #6
Wollmank
The engine knock is extremely loud with 87 octane, I can hear it sometimes with windows closed.
Old 05-16-2013, 12:44 PM   #7
GretchenGotGrowl
But just at idle, right?
Old 05-16-2013, 12:47 PM   #8
Wollmank
Engine knock is the worst when I first start to go from complete stop, after I put it I second gear it goes away ( or maybe not go away, I just can't hear it cause of exhaust is pretty loud)
Old 05-16-2013, 12:49 PM   #9
Wollmank
The squeaking pulley thing sound is at a stop, SOMEtimes it will drop below 500rpm. Not all the time. I have been to the dealership at least 3 times for same problem and all I get is no problem found.
Old 05-16-2013, 12:56 PM   #10
GretchenGotGrowl
I wouldn't think your moved the midpipes much installing the mufflers, but you should check that for rattle from the heads back. As for the idle issue, I still think that's either unmetered air of a vaccum leak. Both of those could be coming from lose fittings on the CAI.
Old 05-16-2013, 01:00 PM   #11
Wollmank
I will check all connections later today, if they are all good, I'm going to install the factory air filter to see if it still is happening. I guess that's my next step.
Old 05-16-2013, 01:01 PM   #12
Wollmank
Oh and thank you!!
Old 05-16-2013, 01:02 PM   #13
GretchenGotGrowl
NP. Hope it works out.
Old 05-16-2013, 01:07 PM   #14
Wollmank
Oh, and I think since I started using 92 octane, my exhaust tips are filthy, black carbon I guess. Guess cause the engine is not fit to utilize 92 octane. But at least I'm not embarrassed at every traffic light. Should I stop using 92 octane, be embarrassed and let the thing blow? Lol????????
