BeckyD @ James Martin Chevy
Old 05-16-2013, 03:26 PM   #1
solteroblues
solteroblues's Avatar
Drives: 2011 Camaro LS IBM
Weird loss of power
I was driving home from work this afternoon, and had it on cruise (40 mile each way, mostly interstate). I was cruising along and all of a sudden, it was almost like cruise turned itself off. I immediately started slowing down. I hit the gas and it accelerated, maybe a slight hiccup, but no problems afterwards. I had Torque running, and did a scan of fault codes, but nothing showed up. There were some O2 sensors that had some readings out of range, but obviously not enough to throw a code.
Has anyone else ever experienced anything like that? (btw, it's a 2011 LS with the LLT and auto trans)
solteroblues is offline   Reply With Quote
Old 05-16-2013, 03:52 PM   #2
Rob21sf
Rob21sf's Avatar
Drives: Black 2011 Camaro LLT
Maybe you accidentally slightly bumped the brake pedal and that usually disengages the cruise control.
Rob21sf is offline   Reply With Quote
Old 05-16-2013, 04:19 PM   #3
solteroblues
I'm pretty sure I didn't, but that is a good guess
