JUICEDMOTORSPORTS
Old 05-16-2013, 04:54 PM   #1
cam99
cam99's Avatar
Drives: 2012 ZL1
intercooler pump questions
Does the intercooler pump run anytime the key is on, or just under boost conditions, or at a certain temperature? Want to verify operation, but not sure when it will be on. I would assume if you take the intercooler res cap off during operation you should see some water movement. Also is there a way to install a switch to run constant so temp can be lowered while sitting in the staging lanes at the track.
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
on hoosier drs and skinnies
@ PRP with 1100DA
cam99 is offline   Reply With Quote
Old 05-16-2013, 05:57 PM   #2
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
Then pump should come on a few minutes after start up, and run the entire time.
When I upgraded my pump, I wired in a switch. There are 3 wires going into the pump. If I remember correctly, wire 4 is brown and is the hot wire. I ran a wire from it up to a switch I put on the bracket under the fuse box. For the hot lead, I hooked to the "bolt" on the front of the fuse box. Always put a fuse inline. I also have the stock fans wired to come on, on low speed with another switch.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 05-16-2013, 09:04 PM   #3
The Baron
The Baron's Avatar
Drives: 2013 zl1
I thought about bypassing mine so it could run while the car was off, that's when it needs to run.. the car jyst flat needs a ice tank if you are not willing to spray meth...
2011 cts-v coupe (pinky) wifes car.. ls9 cam c.a.i. 11.44
2007 corvette vert ..retired..
2013 zl1 stock blower stock ci 20" wheels 10.36 135...so far..
The Baron is offline   Reply With Quote
Old 05-18-2013, 06:46 AM   #4
flyingskibiker
flyingskibiker's Avatar
Drives: Cars, Trucks, Bikes, ORVs, Planes
Send a message via Yahoo to flyingskibiker
You can also jumper at the relay, I'm pretty sure (is done to fans). Also, if you are adding another power supply line to an existing one, you should install a couple diodes...
1968 SS w/ 1966 427/425 Sequoia Green w/ Bumble Bee stripe. Always working on it...
Drooling over the ZL1s. It will be my next car if I can manage to pull it off...
flyingskibiker is offline   Reply With Quote
Old 05-18-2013, 08:23 AM   #5
05stram
Drives: 2013 RS - 2013 2SS/RS - 1971 RS
why - heat soak? you trying to drive up supercharger efficiency from a heat soaked engine? I am confused by your statement. Why not circulate the entire cooling system for you theory? Just asking as I have never heard anyone just worry about one portion of the equation.
05stram is offline   Reply With Quote
Old 05-18-2013, 09:02 AM   #6
oldfriend
Drives: Fiat 500 E
The way I see it , he want to have the hability to kep it running even after the engine is turned off , for a period of time ( I think) to help cool the engine faster
Old 05-18-2013, 09:58 AM   #7
cam99
cam99's Avatar
Drives: 2012 ZL1
The idea is in the staging lanes at the drag strip you can have the intercooler pump running continueous while you are waiting for the next pass to help reduce the amount of heat soak in the blower. An ice tank helps this alot because you can keep adding ice to cool the fluid (water) since there is no air passing through the intercooler while you are sitting
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
@ PRP with 1100DA
Old 05-18-2013, 10:29 AM   #8
05stram
ok gotcha
Old 05-18-2013, 03:11 PM   #9
Blown355
Blown355's Avatar
I wired the hx pump and one of the factory fans to come on with one switch. That way you're not only circulating the hx coolant around, but also pulling air through the hx. Works great at the track. Flip the switch on, close your hood and head to the staging lanes. Factory fan and pump running the entire time.
2017 ZL1
A10
Redhot with stripe
Old 05-18-2013, 03:23 PM   #10
cam99
cam99's Avatar
Drives: 2012 ZL1
This sounds perfect. Where did you tap into the fan and pump circuits?
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
@ PRP with 1100DA
Old 05-18-2013, 03:41 PM   #11
SC2150
Ice is such a hassel to drain and replace and the added weight......do this and never worry again, and ice cant come close to colling this well:
In the staging lanes, switch to "competition mode" and so there is no water to drip, and your looking at 30-40 rwhp gain on a stock ZL1 with the low IAT's. Watch close the video as it shows ambient air temps (outside air), IAT2's, intercoller coolant, engine coolant, throttle position, etc. After a has 30-40 seconds of WOT we switch it on......nothing will cool as efficiently or as quickly as long as you like and not rob any HP and it only adds 18-19#'s total.
Old 05-18-2013, 04:05 PM   #12
alssiri
alssiri's Avatar
Drives: 2012 ZL1 A6
SuperChiller is the way to go I have it on my MagnaCharged SS & my ZL1 .
Never worry about power drop cause of heat soak or Boost drop cause of hot IAT's .
Ahmad
2012 ZL1 A6
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Corsa Sport Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, AGP Dual Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
2015 Rear Fascia Conversion, Z/28 Side Skirts, Flares, Spoiler & Diffuser , ACS Quarter Ports, ShowStopper's Side Marker's, LightWurkz Halo's.
Sosche With KenWood, SLP pod with PLX guage, DashLogic .
alssiri is offline   Reply With Quote
Old 05-18-2013, 04:12 PM   #13
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
HOLY SHIT.................. I want one.
Old 05-18-2013, 06:50 PM   #14
crg
Drives: '68 Camaro SS, '74 Corvette
I know that it bypasses the factory hx when the ac is on, but would you also benefit from larger hx for winter months or while at wot. Just wondering a out having engine tuned with such low iat and when on the hx the tune being off
crg is offline   Reply With Quote
