SDTW Custom Wheels & Tires
Old 05-16-2013, 07:23 PM   #1
theham3
theham3's Avatar
Drives: 2011 VR RS/2LT K@N CNT Cat Back
Help with scratches
My Camaro is a 2011 in Victory Red. I bought a PC and polishes from Chemical Guys. I got their V38, V36, and Mirrior Wet polishes. I also got their Hex-Logic orange, white, and black pads. I wathced alot of thier videos and others on the forum. I still have scratches and it is driving me crazy. Am I missing something or are do these products just suck? The scratches are not deep and are in the clear coat for sure. I used over the counter clay from Mothers. Any suggestions would be greatly appreciated.
theham3 is offline   Reply With Quote
Old 05-16-2013, 07:24 PM   #2
LBreezie
LBreezie's Avatar
Drives: 2012 Camaro 45th anniversary
im at a loss for words. you did everything i could think of
LBreezie is offline   Reply With Quote
Old 05-16-2013, 07:31 PM   #3
Ohten
Ohten's Avatar
Drives: Granite Crystal Challenger SRT
It takes time and patience,it took me two weekends to get the majority of scratches out my new 13.Guess what I still have a few that needs attention but I am the only one that can spot them.
Take your time and work small sections and you will achieve what you are looking for.
Ohten is offline   Reply With Quote
Old 05-16-2013, 07:56 PM   #4
theham3
theham3's Avatar
Thanks
I guess I will slow down and take more time. I am a bit impatient.
Old 05-16-2013, 08:07 PM   #5
vandervortadam
Drives: 2010 Camaro 2ss black 21's
I had no luck with the adams big foam pads. So i went to the 4" foucus pads and work awesome. Never going to use big pads again. Dont know if you can get 4" hex logic pads.
Posted from Camaro5.com App for Android
vandervortadam is offline   Reply With Quote
Old 05-16-2013, 08:22 PM   #6
ec1990
Drives: 2012 AGM SS
V36 also doesn't have much cut at all, if you like CG look at V32, or Menzerna FG400/1000, M101/M105, Optimum Hyper Compound Spray
ec1990 is offline   Reply With Quote
Old 05-16-2013, 08:23 PM   #7
ec1990
Drives: 2012 AGM SS
The 7" pads especially on a Porter Cable are just too big, you can look up 4" hydrotech's from Autogeek, the Cyan ones have great cut as well as the Tangerine.
Old 05-16-2013, 08:30 PM   #8
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
There's no way M101 is needed on a brand new camaro unless it was washed with steel wool., m105/205 would make a lot more sense.
Sent from my Galaxy Nexus using Tapatalk 2
[B]
Old 05-16-2013, 09:04 PM   #9
theham3
theham3's Avatar
Camaro dream,
With the pads I have will the megs you suggested work better then what I have?
Old 05-16-2013, 09:11 PM   #10
CamaroDreams07
Drives: Slow V6
Originally Posted by theham3 View Post
Camaro dream,
I would assume so. I have never heard good things about CG polishes. In fact I've heard nothing but bad things. And that megs combo is one of THE gold standards in polishing.
That being said, the guys are right when they say 7" pads are too big for a PC. You want 5.5" pads for any real correction. That's the perfect size for a PC.
[B]
Old 05-16-2013, 09:23 PM   #11
theham3
theham3's Avatar
I do have the 5.5 in pads. Thanks for the info.
Old 05-16-2013, 09:46 PM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
What is your technique? That is probably the number one cause of poor results. I've never used CG's polishes so I can comment but I find it hard to believe they suck bad enough to not work. They may not be as efficient as others but they have to work.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-16-2013, 10:03 PM   #13
ec1990
Drives: 2012 AGM SS
From what I've read is they are quite weak in terms of cut, except for V32 but even still it doesn't compare to the products that have been around for quite a while.
But good question, he may not be using enough passes or pressure to make a noticeable difference.
Old 05-16-2013, 11:23 PM   #14
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Post a video of your technique
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
