HURST
Old 05-17-2013, 12:31 AM   #1
driarene
driarene's Avatar
Drives: 2LS Summit White
Help! headlights flickering on and off
please watch:
so this started happening a week ago. the connections are all there but maybe something may be loose? i cant tell where the problem is. I saw the guy that helped me out with hooking it up enough to fix it if i find out whats wrong but i have no idea what it may be :/
i got an hid kit from the retrofit source if that helps any, thanx in advanced
driarene is offline   Reply With Quote
Old 05-17-2013, 01:08 AM   #2
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
You have a faulty connection somewhere. You going to have to check everything. Look very close at your grounds and any crimp connections. Your grounds need to be clean and tight. Take them off and grind down to BARE metal. Then tighten them and apply a sealer over them to prevent contamination.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 05-17-2013, 07:15 AM   #3
SSMickey
SECC
SSMickey's Avatar
Originally Posted by Caddyroger View Post
It should be under warranty so take it in and have them to check it out.
Not since she added the HID kit.
Old 05-17-2013, 01:58 PM   #4
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
Opps failed to read here she had the HID kit installed.
Caddy
Caddyroger is offline   Reply With Quote
Old 05-17-2013, 02:28 PM   #5
MGD
MGD's Avatar
Drives: 16 Camaro SS
Did you test the lights with the engine running and the headlights turned on?
On a 2LS, the headlights are the DRL's and therefore come on with lower voltage. Your balasts may not like that and they start flickering.
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
MGD is offline   Reply With Quote
Old 05-17-2013, 04:55 PM   #6
SSMickey
SECC
SSMickey's Avatar
Her headlights flicker when she hits a bump or even slams the car door. Very good indication of a faulty connection.
Old 05-17-2013, 09:49 PM   #7
driarene
driarene's Avatar
I think it might be something with the grounds cuz when we were installing it we had a hard time finding good grounds so ill try doing that this weekend and hopefully it'll work
Old 05-17-2013, 10:03 PM   #8
jmontalvo
jmontalvo's Avatar
Drives: 2011 Rally Yellow 2LS
THIS HAPPENS TO ME ALL THE TIME AND I KNOW EXACTLY WHAT IS WRONG!!!
Ok so my friend and I were fixing my halos and adding a heritage grille yesterday and my passenger side headlight didn't want to turn on. Usually, I would go over a bump and there would be times when nothing would happen, it would flicker, or the headlight went out completely. I always thought it was the connection to the HID but he started moving things around and apparently it's the HID ballast. He moved it and it would flicker and he kept moving it until it turned on.
|Trifecta Tune|Custom Magnaflow Exhaust|Cold Air Inductions C.A.I.|BBK LTs w/ HFC|Anvil Rear Notch Glossy CF Spoiler|Body Color Heritage Grille|10 spoke polished ZL1 replica wheels|VMAX ported TB|RS Headlights|Night Owl RGB Halos
jmontalvo is offline   Reply With Quote
Old 05-17-2013, 10:10 PM   #9
SSMickey
SECC
SSMickey's Avatar
Post back and let us know what you find. Take your time and a break every now and then and you'll be fine.
Old 05-18-2013, 04:43 AM   #10
driarene
driarene's Avatar
ill try that as well, ill try looking at all of my connections
i will, thank you. hopefully ill have an answer as to why its doing this :/
Old 05-20-2013, 10:58 PM   #11
driarene
driarene's Avatar
Thanks for ur help guys!
eagle eyes, headlight help, headlights, hid kit
