SDTW Custom Wheels & Tires
Old 05-17-2013, 04:00 PM   #1
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Simple 1LE Tire Pressure Question
Very simply, what tire pressure do you set you 1LE tires at when cold for daily driving.?
Door jam says 32/32. Owners manual says 44psi for speeds over 100mph.
I do have experience setting up cars.....just curious what everyone else is doing with these for daily driving
FYI This is 1LE specific and not even ZL1 with the same wheels because it is 300lbs heavier, different suspension, different rear tires....
Thanks
Matt
Old 05-17-2013, 04:32 PM   #2
Irishblackcoffee
Irishblackcoffee's Avatar
Drives: 13 1LE GBE M6, 12 VR M6 #872
I'm running 32 front and 32 in the rear.
'13 1LE "MAX" '12 ZL1 "SAPPER"
Irishblackcoffee is offline   Reply With Quote
Old 05-17-2013, 08:24 PM   #3
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
Mine was delivered at 31. Same range as any other street car/tire I've owned. Typical street tire pressure is 30 - 35. Aside from track use, this car/tire is no different.
Perm-a-grin in place.....
JimE is offline   Reply With Quote
Old 05-17-2013, 08:31 PM   #4
MPHS_AGM
MPHS_AGM's Avatar
Drives: 2013 Camaro 2SS/RS/1LE AGM
I shoot for 32.
Current:
2013 AGM 2SS/RS/1LE-NPP
Past:
2002 Z28 Navy Blue A4 [traded]
1996 Camaro V6 Black [traded]
MPHS_AGM is offline   Reply With Quote
Old 05-17-2013, 08:54 PM   #5
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
32 here
BigBlock69RS is offline   Reply With Quote
Old 05-17-2013, 09:33 PM   #6
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
Where does it say 44psi over 100mph? 32 cold and close to 40psi hot during track
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
Old 05-17-2013, 09:36 PM   #7
Midnight Rat
Midnight Rat's Avatar
Drives: 2013 SS 1LE
32
Midnight Rat is offline   Reply With Quote
Old 05-17-2013, 10:37 PM   #8
coreyaustin17
NEC5 C-HOLE CHAMP
coreyaustin17's Avatar
Drives: 2013 camaro 2SS/RS 1LE 1 of 221
36
coreyaustin17 is offline   Reply With Quote
Old 05-17-2013, 10:44 PM   #9
The Stig
knows 2 facts about ducks
The Stig's Avatar
Originally Posted by coreyaustin17 View Post
36
Re-check your door jamb
Click to view my build thread
Old 05-18-2013, 12:29 AM   #10
Nick S
Nick S's Avatar
Page 10-58 in your Camaro owners manual. I just searched for it myself and found it there. Here's a copy and paste from the paragraphs of the owners manual.
10-58 Vehicle Care
Make sure vehicles with 245/
45ZR20 103Y, P245/50ZR19 104W
and 275/40ZR20 106Y size tires are
inflated to the recommended cold
inflation pressures before operating
the vehicle at speeds over 160 km/h
(100 mph). See
Vehicle Load Limits on page 912
and Tire Pressure on page 1056.
Make sure vehicles with 285/
35ZR20 (100Y), and 305/35ZR20
(104Y) size tires are inflated to
300 kPa (44 psi) before operating
the vehicle at speeds of 160 km/h
(100 mph) or higher.
Return the tires to the
recommended cold tire inflation
pressure when high-speed driving
has ended. See
Vehicle Load Limits
on page 912 and Tire Pressure on
page 1056.
Nick S is offline   Reply With Quote
Old 05-18-2013, 05:39 AM   #11
bpdcop100
bpdcop100's Avatar
Drives: 2013 1LE,
Need some clarification. I have run my 1LE six track days so far this year. I have never started the tire pressure off at 44 psi cold. The track I ran was a clockwise rotation and the left front gains 3 psi more than the rears. The air temp was in the 30's in March and in the high 50's in April. The rears had 30 psi at cold and after the 25 minute sessions had 36 psi. If anyone has run these tires at 44 psi cold on a road course I would like to hear the hot psi readings.
bpdcop100 is offline   Reply With Quote
Old 05-18-2013, 05:54 AM   #12
Chris97b
Chris97b's Avatar
Drives: 2012 45th SS
I was under the impression that the only advantage to running high pressures for high speeds was to reduce rolling resistance due to a smaller contact patch. I'm not exactly a physics expert, but wouldn't this just make it easier/faster 0-100mph? Is there any other advantage to high pressures as opposed to standard 32-35psi for high speed operation?
Sorta OT I know, but inquiring minds want to know
Chris97b is offline   Reply With Quote
Old 05-18-2013, 06:59 AM   #13
Dropspeed
Dropspeed's Avatar
Thank you for all of the responses.
My questions was purely to see what everyone else was doing with theirs.
I am running 32 cold as well, and will start at about 38 cold next weekend when she hits the track.
Yes, lots of factors can go into setting the air pressure at the track, this was simply a daily driving psi question.
Thanks,
Matt
Old 05-18-2013, 07:55 AM   #14
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I run mine at 30 psi cold. It goes up to about 33 with mixed driving ie. city/highway. If I do a 100+ mph blast I don't think twice about my tire pressure. If I was going to do a top speed run at an event I would bump up the psi. I'd research what to psi use.
The car came with roughly 36 psi or 38 psi and it felt like a frigging stage coach.
Firefighter is offline   Reply With Quote
