Old 05-17-2013, 04:20 PM   #1
1Slow6.2
1Slow6.2's Avatar
Drives: 2013 1LE camaro
Oil separator
I have the oil separator that came with my 1LE sitting in the trunk. It's been there about two weeks. My question despite it saying its for track use only should I install it and run it daily as my car Is my dd? Or should I just hold off until I get the rx catch can?
1Slow6.2 is offline   Reply With Quote
Old 05-17-2013, 06:04 PM   #2
Bauer2
Bauer2's Avatar
Drives: 2013 2SS/1LE and 2009 R1
I have the factory one installed now and will also add the RX can when it finally comes in. Several people are running both at the same time.
Bauer2 is offline   Reply With Quote
Old 05-17-2013, 06:59 PM   #3
coreyaustin17
NEC5 C-HOLE CHAMP
coreyaustin17's Avatar
Drives: 2013 camaro 2SS/RS 1LE 1 of 221
http://www.camaro5.com/forums/showthread.php?t=295678
if you read down myself and bauer2 both stated our opinions
coreyaustin17 is offline   Reply With Quote
Old 05-17-2013, 07:27 PM   #4
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Use both
Old 05-17-2013, 07:45 PM   #5
SC2150
Use both. It does not need to be emptied as it allows the oil to drip back into the valve cover wehn shut off, this oil is not contaminated like the dirty side oil is as thayt should never be returned to the crankcase.
Old 05-17-2013, 07:50 PM   #6
bluBlud
bluBlud's Avatar
Drives: 2013 2SS/RS/1LE
I have both installed. My only slight concern in the tube running from the cai to the oil separator can rub against the upper barb on my catch can. Not sure if it'll wear or not, or I could move the can down a bit but I really don't want to keep working the pulley bolt. I chose the elite can since it seemed easier/cleaner to empty.
http://www.camaro5.com/forums/showth...=287757&page=2
bluBlud is offline   Reply With Quote
Old 05-18-2013, 12:43 AM   #7
1Slow6.2
1Slow6.2's Avatar
Thanks guys for the responses
Sent from my hip pocket.. While slapping 5th.. As your reading my plate
