Rick@Livernois
Old 05-17-2013, 05:09 PM   #1
D2enigma
D2enigma's Avatar
Drives: 2016 2SS
2013 Dusk edition Front splitter with gaps
I've been talking to GM regarding gaps on the front splitter on my 2013 Dusk edition. Looks like they are coming to conclusion saying that it is how it is designed. I find that hard to believe. Camaro built to use parts that are designed to not fit?
I already took it to the dealer and they have already replaced it with another one, but the gap is still there. I'm having hard time figuring out what I can do to get it fixed.
Could anyone here post some pictures of your front splitter if you have 2013 Camaro dusk edition? I've posted mine as a reference.
D2enigma is offline   Reply With Quote
Old 05-17-2013, 05:30 PM   #2
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
double sided tape or emblem tape.......could make it closer maybe of it were pressed into place hard, not everything can be perfect......, look and see how it is mounted, maybe there is a place where you could reem out the plastic and hold it in tighter, or place another mounting screw.....
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 05-17-2013, 05:34 PM   #3
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
The front splitter on the Dusk is the same as the 1LE.
Here is a thread discussing the gap and it has pictures:
http://www.camaro5.com/forums/showthread.php?t=272918
There appears to be a TSB for it
Originally Posted by 2013 1LE View Post
If the ends of your spilitter is sticking out there is tsb dated feb 2013 for them to use a adhesive to fix the ends.
Old 05-17-2013, 06:38 PM   #4
bluBlud
bluBlud's Avatar
Drives: 2013 2SS/RS/1LE
The dealership replaced mine, for what it's worth. Fit is better, whether it was the part and/or installation.
bluBlud is offline   Reply With Quote
Old 05-17-2013, 08:43 PM   #5
Midnight Rat
Midnight Rat's Avatar
Drives: 2013 SS 1LE
there is a tsb, but it calls for glueing the ends to the fascia. another members dealer used fuzer glue and put a bolt on the spliter and then drilled a hole and put a nut on the inside and he said it was holding to this day just fine.
Midnight Rat is offline   Reply With Quote
Old 05-17-2013, 08:47 PM   #6
Midnight Rat
Drives: 2013 SS 1LE
sent you a pm
Old 05-18-2013, 12:08 AM   #7
Dupree878
Dupree878's Avatar
Drives: '13 Dusk Edition 2SS/RS M6
Mine is just like that. I took it as that's just the way it was designed.
Dupree878 is offline   Reply With Quote
Old 05-18-2013, 07:18 AM   #8
Chi-One
Chi-One's Avatar
Drives: 2013 DUSK Special Edition
I just took the photo. It does not appear as bad as yours.
1 of 56
Chi-One is offline   Reply With Quote
Old 05-18-2013, 11:45 AM   #9
suzbndt
suzbndt's Avatar
Drives: 2010 Camaro SS 2011 Mustang GT
my slp one fits perfect. just upgrade.
suzbndt is offline   Reply With Quote
