Old 05-17-2013, 09:23 PM   #1
Camaro4SS
Camaro4SS's Avatar
Drives: 2013 Camaro RS 2LT
Rally Stripes & Detailing Question
Is there a difference between the vinyl from Chevy or aftermarket (3M)? Price is Chevy $298.99, 3M $120.00
What can I use to get a few swirl marks off of my new 2013 Black Camaro?
Camaro4SS is offline   Reply With Quote
Old 05-17-2013, 09:33 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
No idea on the first question. This isn't the right section for that.
You'll need a polish to remove swirls.
Sent from my Galaxy Nexus using Tapatalk 2
[B]
Old 05-18-2013, 01:18 AM   #3
SS_Los
SS_Los's Avatar
Drives: 2011 CGM 1SS L99
You might also want to invest in a porter cable. Once you eliminate the swirls marks, the car needs to be washed using the 2 bucket method in order to avoid more swirl marks. Here's a link to a thread about how to properly detail a car. http://www.camaro5.com/forums/showthread.php?t=19526
SS_Los is offline   Reply With Quote
Old 05-20-2013, 04:11 PM   #4
POWERMAN
POWERMAN's Avatar
Drives: '13 Charger Sxt+
OP, if your swirls arent that deep, look into using a glaze.
It's filler properties would help conceal swirls and in the process help you keep your existing level of clearcoat.
Personally, it would be nice to save polishing for 2-3 years down the line, given that your car is relatively new..
POWERMAN is offline   Reply With Quote
Old 05-20-2013, 04:14 PM   #5
CamaroDreams07
Drives: Slow V6
This is such a misleading post. The amount of clear removed in modern polishing systems is so minimal you could do it dozens and dozens of times and not get through your clear. There's absolutely no reason to wait unless you like looking at swirls.
[B]
Old 05-20-2013, 04:14 PM   #6
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Polishing a car can be done many times without fear.
It's when you start using M105/M101 over and over again due to bad washing technique that you have to start worrying.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
