BeckyD @ James Martin Chevy
Old 05-18-2013, 08:52 PM   #15
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
would bet money an axel let loose... and don't kid yourself these tires are plenty sticky when heated up... please post back when you find out what broke.... maybe you could add a few more details like you dropped the clutch at 6k...
tramtwo is offline   Reply With Quote
Old 05-18-2013, 08:59 PM   #16
el ess A
formerly "el ess X"
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Hey, could be a warranty item as well...maybe.
2010/2013 Camaro
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 05-18-2013, 09:03 PM   #17
Supercharged SS
Drives: 2010 Camaro
I just had a very similar experience. The car was bouncing down the track. Sounded like the rear grenaded. The car wounded move. Putting it in park sounded awful. Turned out that I snapped a DSS axle in half. They sent us some upgraded ones.
Old 05-19-2013, 12:13 AM   #18
Milkdudd
Drives: Saturn XR V6
Sorry......But why would it NOT be a warranty item. Someone please explain the difference. Thanks.
Milkdudd is offline   Reply With Quote
Old 05-19-2013, 12:15 AM   #19
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
Depends on his mods if he has any.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 05-19-2013, 01:40 PM   #20
el ess A
formerly "el ess X"
el ess A's Avatar
Yep. If stock they SHOULD warranty the rear. But if he's got those "unauthorized" power adders, or other drive train mods, then you roll the dice. Obviously he wouldn't say he was at the track, even if he was. There's no other information available to make even a ballpark determination.
2010/2013 Camaro
Old 05-19-2013, 07:48 PM   #21
Chevrolet Customer Svc
Drives: GM Vehicles
Originally Posted by bombton_1le View Post
so last night i was trying to launch my car and instead a speedy take off all i heard was a pop and i wast moving from my experience sounds like i took out some teeth from the ring
Hello bombton_1le,
That's not good news at all, sorry for this issue you’re experiencing. Have you considered visiting a dealer for this? I could help set you for a visit and service of this issue a a dealer nearest to you. Could you please private message me your name, address, phone number, VIN and current mileage? I will look into this issue further for you.
Reggie B.
Chevrolet Customer Care
Old 05-19-2013, 10:59 PM   #22
bombton_1le
Drives: 2013 Camaro 2SS/RS 1LE
sup guys,
i broke down at midnight and it was pretty dark all i was working with was a cellphone light, didnt see no fluid on the floor or parts on the floor. the car would sometimes move normally for a few feet then it would stop and hear all kind poping and knocking from the rear and it wont move. i managed to drive it up the flat bed and when i was almost to the top it gave out and started making loud noises from the rear.
i got it towed to my dealer they said they would call me back saturday but they didnt and there closed sunday. ill follow up tommorow and see whats going on. My car only has 1500 miles and as far as mods go just intake and lowering springs
bombton_1le is offline   Reply With Quote
Old 05-19-2013, 11:04 PM   #23
bombton_1le
Originally Posted by Chevrolet Customer Svc View Post
Hello bombton_1le,
Reggie B.
Already taken care ofv, thanxs. OnStar came in handy
Old 05-19-2013, 11:12 PM   #24
yotaman96
yotaman96's Avatar
sup guys,
That does sound like the rear dif.
Old 05-20-2013, 02:01 AM   #25
Bauer2
Bauer2's Avatar
Drives: 2013 2SS/1LE and 2009 R1
Yep sounds just like mine did on my Silverado when it grenaded. Was going down the interstate them it felt like I hit a big pot hole then I had no pull the engine would rev but I didn't go anywhere. I looked at it once I pulled over and it looked like a grenade when of being the housing. All I can think of was the g80 locker blew and then caused the rest to go. I had all those same popping and grinding noises though.
Good luck!!!
Sent from the fast lane!
Bauer2 is offline   Reply With Quote
Old 05-20-2013, 12:20 PM   #26
bombton_1le
talked to my service writter today he comfirmed the rear end gave out, waiting for GM for approvel to be sp-order the rear end
Old 05-20-2013, 12:55 PM   #27
right to travel
Drives: 2013 Camaro 1SS 1LE SW
id def want to know what you did to break it when you can tell us. seems like some of these 1le upgrades need an upgrade. axels, gears, trans issues
right to travel is offline   Reply With Quote
Old 05-20-2013, 04:47 PM   #28
Milkdudd
Is this a common occurrence? Not just on 1LE's but SS's in general. I am VERY familiar with the actual diff housing as I worked on the engineering end of the CNC machining of the part. Zeta platform uses both one piece and two piece diff housing. They never told us what cars they went in but I'm guessing the beefier two piece goes in the SS. Please tell us WHAT in the rear end failed when you find out. Thanks.
