Old 05-18-2013, 02:44 PM   #1
ec1990
Drives: 2012 AGM SS
3M Paint Defender (Spray-on Clear Bra) Review
I will be updating this as it dries.
3M states it takes 2-4 hours to dry and 1-4 days curing time for it to be water repellent, I believe mine will be done at the minimum if not before as this was done at 90 degrees and the car is parked outside in the sun.
So for this I did a control the driver's side rocker panel was sprayed with the spray film and the passengers side was cleaned and clayed at the same time but left exposed to the elements.
Beginning out here's the kit, I just ordered the spray-can only
It included the spray-can and 1oz of wax to assist in removal.
For the following areas here's the recommendation of cans needed
Leading Edges - 1 can
Full Hood - 2 cans
Front Bumper - 1 can
Mirrors - 1/4 can
Rear Bumper - 1 can
Trunk Lid - 1 can
Rocker Panels - 1 can
You can pick up a kit which includes a microfiber towel and plastic sheeting for $12 but I decided just to go to Home Depot and pick up the sheeting on my own, it was located in the paint section.
Here's what I picked up and it worked quite well.
Much cheaper than the kit.
In total here are all the items I personally used to accomplish this.
A list:
1 bottle with ONR mixed in clay lube/QD solution
2 Microfiber Towels (One for washing, one for buffing the wax)
Clay
Foam Applicator for wax
Plastic Sheeting
Painter's Tape for the sheeting
Knife
Spray Film
Wax
For prep I used ONR and cleaned both panels followed by using ONR as a clay lube.
A bit of dirt on the clay, but not too bad overall, the car was washed a week prior.
Wax:
The wax was extremely easy to apply, but 3M gives you WAY too much, I barely used a 1/4 of the pack and also directs you to not let it dry to a haze, only to apply then buff off. Unfortunately it's not resealable so it was thrown away after use. That was how much product I used and was probably overkill as well.
Now time to tape up the vehicle and sheet it up.
Especially make sure you tape up the creases, near the door, etc…
Here it is sprayed on
30 Minutes After Application
I will update it as it dries after a few hours, and in a couple days once it's cured. That area on the bottom right, is part of an Xpel clear bra and I will be using that to compare the 3M Spray film too as well.
Overall though:
Application was super easy, prep was as easy as it can get, wash, wax, prep, spray. Already though I can see a few high spots but I expect them to level out as it dries. It also is very thin, nowhere close to a plastic clear bra, so for front bumpers it won't handle up to the repeated rock chips, but for lesser traffic areas like mirrors, the roof (specifically front half), rear fenders It's definitely an option, and I think better than taping it up for the drag strip.
Thanks for reading!
ec1990 is offline   Reply With Quote
Old 05-18-2013, 03:39 PM   #2
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Thanks for posting. Sure looks like an interesting product.
I'm a little confused, you wax before you apply it?
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 05-18-2013, 03:52 PM   #3
ec1990
Drives: 2012 AGM SS
Correct. I don't understand it either, but according to 3M it allows for easier removal, and is as directed in their application pamphlet.
Old 05-18-2013, 03:59 PM   #4
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
Laus Deo
charlietuna is offline   Reply With Quote
Old 05-18-2013, 04:25 PM   #5
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
Very interesting
Sent from my SPH-L900 using Tapatalk 2
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 05-18-2013, 04:58 PM   #6
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
Does it still look all rough and orange-peely when it dries completely? Looks more like old fashioned chipguard than a clear bra so far.
joeybsyc is offline   Reply With Quote
Old 05-18-2013, 05:05 PM   #7
ec1990
Drives: 2012 AGM SS
Right now it does slightly, it's smoothed out slightly, but mostly just looks hazed over at the time.
Old 05-18-2013, 08:07 PM   #8
ActNup NY
ActNup NY's Avatar
Drives: 2011 1LT Black Camaro
The DREAM is free... It's the HUSTLE that is sold seperately
ActNup NY is offline   Reply With Quote
Old 05-19-2013, 10:36 AM   #9
ec1990
Drives: 2012 AGM SS
A couple updates roughly 20 hours after.
It is still appearing a bit cloudy and you can see high spots. Unfortunately in the instructions it doesn't state what you can do with high spots, only that you have roughly 10 minutes to fill in low spots.
Here are a couple pictures
Driver's Side (With spray-on clear-bra)
Passenger's Side (Without)
You can see there's quite a bit of rough texturing to it even almost 24 hours after, 3M does state 1-4 days so I'll continue to monitor and check back.
Old 05-19-2013, 05:09 PM   #10
Pharmaro
Pharmaro's Avatar
Drives: 2011 CGM 2SS/RS
Thanks for reviewing this! Really interested in how this turns out in 1-4 days and I hope you give some "long term" road test updates.
Pharmaro is offline   Reply With Quote
Old 05-19-2013, 05:46 PM   #11
ec1990
Drives: 2012 AGM SS
Will do, I plan on keeping it on there. I'm getting ready for a move so the car will get a solid 1000 mile road trip in roughly a month. I also plan on taking it off after that to test how easily it is to remove. And also compare how the finish looks with and without it. So far it's still slightly cloudy, which isn't comforting from a detailing business perspective because if I was a customer I'd be upset over a cloudy/hazy finish. Especially over the entire front bumper or hood.
Old 05-20-2013, 07:42 AM   #12
gml1998
gml1998's Avatar
Drives: 2010 Synergy Green Camaro
FYI.Our local Autozone stocks this product. 24.99 per can
gml1998 is offline   Reply With Quote
Old 05-20-2013, 08:55 AM   #13
Chevyman2
Chevyman2's Avatar
Drives: 2018 zl1
After waiting the prescribed time I removed the 3m spray on defender from my hood and bumper. The majority of it came off however, tiny specs were found throughout. I clayed, washed, clayed again and washed it in effort to remove this crap.
In the end it did more harm than good, my rockers are only thing area that turned out fine. If I had to do over again I would NOT use.
Chevyman2 is offline   Reply With Quote
Old 05-20-2013, 01:16 PM   #14
ec1990
Drives: 2012 AGM SS
48 hours after
Still extremely hazy and the high spots didn't level themselves out leading to a glaring problem since there's no instruction on how to level it. I felt if I tried to wipe it down with a microfiber it would not only leave a hole but probably destroy a towel as well. But it still has 2 days for 3M's cure time, so we shall see.
If that's not bad enough, here's the dirt pulled off my windows after just a week.
Tip: Having a car parked outside 24/7 in the southwest is extremely dusty.
