Caryle Racing
Old 05-18-2013, 06:07 PM   #1
EncoreCamaros
EncoreCamaros's Avatar
Drives: 2010 Victory Red Camaro SS/RS LS3
pfadt coilover issues
Today i installed my pfadt coilovers literally by the book! After i finished and lowered the car to adjust the ride height, i set both front and back coilovers all the way down and worked my way up to the ride height i wanted. The only problem was that i didnt even touch the front coilovers which were bottomed out and they were still sitting way too high. Almost factory height! I installed everything while reading the instructions and everything went very smooth until I came across this problem. Dont know if its me that screwed up the install or what. please help me out
ARH 1 7/8 headers catless 3'' long system, Whipple sc 4.00 pulley 9 lbs boost, msd boost-a-pump, CAI intake, Pfadt coilovers, toe links, trailing arms, solid cradle bushings, sway bars, Forgestar CF5 19x9.5/19x11, M/T et street II radials
EncoreCamaros is offline   Reply With Quote
Old 05-18-2013, 06:49 PM   #2
Supercharged SS
Drives: 2010 Camaro
Which coil overs do you have?
Old 05-18-2013, 07:02 PM   #3
EncoreCamaros
they are the street coilovers, not the drag ones
Old 05-18-2013, 07:04 PM   #4
EncoreCamaros
Heres a pic
Old 05-18-2013, 07:08 PM   #5
Supercharged SS
Drives: 2010 Camaro
I have the brand new drag race specific coil overs. My chassis guy had a similar problem. The front spring was to hard and the rear was to soft. Pfadt offers me another spring package.
Old 05-18-2013, 07:11 PM   #6
L99CAMA2011
L99CAMA2011's Avatar
Old 05-18-2013, 07:19 PM   #7
EncoreCamaros
Supercharged ss was the problem solved after the new springs?
Old 05-18-2013, 07:22 PM   #8
L99CAMA2011
Front spring is probably too tall maybe 10" instead of 8".
Old 05-18-2013, 07:23 PM   #9
Supercharged SS
Drives: 2010 Camaro
Yes it was. It allowed the tech to adjust the ride height to what he wanted. The way we got them we also had both adjustments maxed out. The front was so bad it looked like it was pulling a wheelie not to mention you couldn't even push down on the nose. Pfadt knew what we wanted and sent them to us. It was only a 25lb difference in spring weight but it worked for us.
Old 05-18-2013, 07:24 PM   #10
Supercharged SS
Drives: 2010 Camaro
We got the same height springs. Just 25 lbs lighter in front and 25 lbs heavier in the rear.
Old 05-18-2013, 07:24 PM   #11
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
looks awesome sorry you are having a problem. Keep us posted please I am thinking of getting these soon!
CHMSC is offline   Reply With Quote
Old 05-18-2013, 07:32 PM   #12
EncoreCamaros
Same exact thing, im maxed out and it does look like its doing a wheelie. I emailed pfadt, hopefully they get back to me soon
Old 05-18-2013, 07:36 PM   #13
L99CAMA2011
That's weird though, I went from 225lbs on my Eibach kit to 325 lbs and it wasn't that much of a height difference.
Old 05-18-2013, 07:49 PM   #14
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
wow glad i didnt but these yet seems like some kinks still need to get worked out.
Whipped416 is offline   Reply With Quote
