BORLA
Old 05-18-2013, 08:15 PM   #1
Wuiquen
Wuiquen's Avatar
Drives: 2011 Summit White 2LT/RS
Catch can Check Valve.. HELP
quick question, I while back I got a plain fitting to replaced the check valve on the catch can because it was making noises which we decided probably was bad. After a long moving cross country and more BS.. finally I get to look into this.. My questions is how do I remove the check valve from the catch can?? I can see that the outlet (outside one) can be unscrewed; however, the center wont let me do that. I cant figure out how to get the center fitting out either. I pull it out and no luck.. IDK what to do.. by the way I am guessing the center is the check valve.
Any advice is welcome.. I attached a pic of the catch can so its easier to see what Im talking about.
Wuiquen is offline   Reply With Quote
Old 05-18-2013, 09:02 PM   #2
mickmosh
Drives: 2017 Camaro 2SS
Pull it out it's in there too. You won't break it just pull straight up and out it'll come. Mine was rattling so I pulled it apart to get check vavle out of it. So nice without the rattle make noise....:-)
mickmosh is offline   Reply With Quote
Old 05-18-2013, 09:44 PM   #3
Wuiquen
Wuiquen's Avatar
u mean pull out the middle fitting??
Old 05-18-2013, 10:03 PM   #4
mickmosh
Yes the center one will pull out and the out side one will twisted out.
Old 06-12-2013, 10:41 PM   #5
Wuiquen
Wuiquen's Avatar
thank you.. got this done a wk agoo..
Old 06-13-2013, 12:17 AM   #6
c_cook94
c_cook94's Avatar
Drives: 2011 Rally Yellow 1LT
Mine has been rattling for a while now. Just remove it? Is everything still going to work properly?
c_cook94 is offline   Reply With Quote
Old 06-13-2013, 05:54 PM   #7
Wuiquen
Wuiquen's Avatar
No u need to get another fitting to the replace the check valve. Ask Tracy for one.
