Cold Air Inductions
Old 05-18-2013, 08:16 PM   #1
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Drives: 2010 Camaro LT/RS M6
You guys won't believe this
Hey its me...the guy with the brand new 2013 LLT motor. Car started horribly. Like one cylinder would start and the rest would join in over about 5 seconds. Then the car ran fine. Well when we got back to the car to come home (5 hours after getting to our destination) it did it again. So I don't know what's going on
Sent from my DROID RAZR HD using Tapatalk 2
CamaroC-17 is offline   Reply With Quote
Old 05-18-2013, 08:19 PM   #2
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
Did the CEL come on during your trip? Could have left a vacuum line loose. That would kick a CEL, though.
Bye bye, Bumblebee!
Old 05-18-2013, 08:20 PM   #3
RubyCamaro
Jan
RubyCamaro's Avatar
Ya think that Camaro has a ghost haunting it? Weird.
Old 05-18-2013, 08:21 PM   #4
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
No CEL. Triple checked hoses. Also if I left one off the car wouldn't run well at all. After about 5 seconds after turning the key, all cylinders are firing and sounds normal. Car runs great.
Old 05-18-2013, 08:26 PM   #5
strych9
Gone Euro!
strych9's Avatar
Hmm. Sounds like the fuel pump might be draining back when you leave it sit for a bit, like a bad check valve. Only way to be sure is to put a fuel pressure gauge on it and see if it holds pressure when you shut it down.
Bye bye, Bumblebee!
Old 05-18-2013, 08:30 PM   #6
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
I know. I'm at a loss...I honestly just want to push it off a cliff. I wish corporate GM would do something if I contacted them. My was my first brand new car I bought on my own, drove it out of the showroom and have had nothing but problems. I would like to think they would want to make it right.
Old 05-18-2013, 08:39 PM   #7
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Hmm..never done that before. What I don't get is that yesterday (first day with new motor) everything was fine. Had multiple starts and one start was late at night after it sat awhile.
Old 05-18-2013, 08:41 PM   #8
Rob21sf
Rob21sf's Avatar
Drives: Black 2011 Camaro LLT
Try disconnecting your battery to let things reset and see if that helps.
Rob21sf is offline   Reply With Quote
Old 05-18-2013, 08:47 PM   #9
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Worth a shot. Tired of going to the dealer
Old 05-18-2013, 10:07 PM   #10
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Fill'er up with some local good quality gas, and maybe throw in a bottle of gas treatment that takes any water contamination out as well as cleaning injectors.
Old 05-18-2013, 10:23 PM   #11
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Look into the lemon law. You shouldn't have to go through all of this.
BaylorCamaro is offline   Reply With Quote
Old 05-19-2013, 09:07 AM   #12
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
I tried something. I put key yo run position this morning for 5 seconds,turned to off and then started. So it primed the fuel pump. It started better sounding like only one cylinder was off but quickly recovered. So I think you may be on to something. Is this in anyway related to any of the work they did putting in a new engine?
Old 05-19-2013, 09:30 AM   #13
strych9
Gone Euro!
strych9's Avatar
I would think not. Check valve is located in the fuel pump in the tank.
Bye bye, Bumblebee!
Old 05-19-2013, 09:34 AM   #14
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Well good enough...funny how all of a sudden there is fuel pump problem. So the fuel pump is in the gas tank?
