Old 05-19-2013, 02:47 AM   #1
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
The ultimate track built ZL1
I am completing several mods to improve handling on the roadcourse as this is where I spend most of my time. Any suggestions on additional items that I should include? I finshed installing everything tonight, however, I am waiting on new wheels as mine were stolen a couple of weeks ago. My wheels will be here this coming week and I will then have tires mounted and slap them on. Cant wait to see how she feels.
The mods are as follows:
Michelin Pilot Super Sport Tires, 285 Front, 315 Rear
Pfadt ZL-Spec Adjustable Sway Bars
Pfadt Lowering Springs
Pfadt Front Trailing Arm Solid Bearing/Bushing
Pfadt Front Lower Control Arm Poly Bushing
Pfadt Solid Mount Aluminum Subframe Bushings
Pfadt Rear Upper Control Arm Poly Bushing
Pfadt Rear Lower Control Arm poly Bushing
Pfadt Rear Trailing Arms and Poly Bushing kit
Racing Brake RB 2-piece Rotors, Front and Rear
Hawk DTC-30 Racing Pads (Front)
Hawk HT-10 Racing Pads (Rear)
69NMYSS is offline   Reply With Quote
Old 05-19-2013, 03:34 AM   #2
Bad@ssCamaro
Rogers' Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
Very impressive upgrade, should definitely improve your confidence and times. You asked for suggestions or ideas, the only thing I can think of which is not on your list are SS brake lines.
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade.
ARH 1 7/8 headers, CAI, BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings, DSS driveshaft ...421 whp...so far.
Old 05-19-2013, 04:17 AM   #3
69NMYSS
69NMYSS's Avatar
Thanks for the suggestion. What is the advantage of the SS lines?
Old 05-19-2013, 04:24 AM   #4
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
Stainless steel lines...less fade I suppose?
2017 C7 GS - WGG, A8. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
Old 05-19-2013, 04:54 AM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
high temp brake fluid too. ATE super blue is great
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 05-19-2013, 05:03 AM   #6
69NMYSS
69NMYSS's Avatar
Thanks, already running Superblue!
Old 05-19-2013, 05:35 AM   #7
ayousef
ayousef's Avatar
Drives: 2013 ZL1
how about some intercooler mods even if you have no engine mods, sounds like a good idea.
On the other hand, I wonder how much of those aftermarket suspension parts do good other than claim, something like the trailing arms and tie-rods, if they claim to fix wheel hop you arent getting any wheel hop on a roadcourse so what are the benefits, and since those were developed on the SS how much different is the ZL1, does it still need those mods?
Going by the if its not broke dont fix it approach.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 05-19-2013, 07:22 AM   #8
swizlstik
swizlstik's Avatar
Drives: 2018 Garnet ZL1 on order (VGXM1J)
I'm thinking those tires are in my future as well. I've heard nothing but good about them. Congrats on the mods!!
swizlstik is offline   Reply With Quote
Old 05-19-2013, 11:45 AM   #9
MPR
MPR's Avatar
Drives: 2013 Camaro ZL1
Is there a reason why you went with the DTC30 front instead of a DTC60?
Spending on a road course most of your time, then I will suggest to start with these
Motul 600 brake fluid instead of the superblue
DTC60 or DTC70 for the front pads if you like hawk
5 point racing seat
5 point harness
300-320 mm steering wheel
4 pt roll cage min
minimum r888 285/315 or better yet hoosiers 295/315/335 in 19's
more aero front splitter and carbon wing
minium double or triple adjustable coilovers
camber kit. need more camber/alignment
LSA VR38DETT 4B11 2ZZ-GE-SC N55 B18C5 302
MPR is offline   Reply With Quote
Old 05-19-2013, 12:28 PM   #10
DrkPhx
DrkPhx's Avatar
Two questions: Can you weight those rotors and compare them to stock? Can you measure the diameter of the rear Pfadt sway bar? Should be 34mm
I would definitely consider the LG Motorsports rear chassis brace. It only weighs 27-lbs and was track tested to help stiffness of the rear suspension. Also curious to know what alignment specs you're going with.
DrkPhx is online now   Reply With Quote
Old 05-19-2013, 03:47 PM   #11
69NMYSS
69NMYSS's Avatar
Already have engine mods and cooling taken care of.
In regards to arms, I am more interested in the poly bushings. Stock arms have rubber, poly is MUCH better suited for the track.
5 point racing seat
5 point harness
4 pt roll cage min
Sorry, when I said I spend most my time on the road course I meant vs. the drag strip. This is still my daily driver so I gotta keep it somewhat reasonable. I had DTC-60's on and they had to much initial bite. I am trying the 30's to see how they perform.
I am waiting for Pfadt's mag coil over system or else I would have went with coil overs instead of springs.
As soon as the new Recaro's are available for purchase I will be buying them.
The RB rotors are a total 16 lbs lighter than the OEM Brembos.
Old 05-19-2013, 03:51 PM   #12
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Those are going to make a huge difference. Nice choices.
Old 05-19-2013, 08:52 PM   #13
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I am not sure that the chasis brace would be needed since he has the soldid subframes. PFADT devoloped one did not bring that to the market for a reason. they said once you go solid bushings it is just not required. the brace is just added wieght.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 05-19-2013, 09:11 PM   #14
OldJedi
Use the Force
OldJedi's Avatar
Drives: 1967 Corvette, 2012 ZL1, 2015 Z51
Send a message via AIM to OldJedi
What engine and cooling mods did you make so far?
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
