Jason 98 TA
Old 05-20-2013, 02:08 AM   #15
Bad@ssCamaro
Rogers' Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
Originally Posted by 69NMYSS View Post
Thanks for the suggestion. What is the advantage of the SS lines?
Originally Posted by djnice View Post
Stainless steel lines...less fade I suppose?
Braided stainless steel brake lines (also known as braided stainless steel brake hoses) are flexible hoses fitted to a hydraulic brake system. The intent of braided stainless steel brake lines is to improve brake system effectiveness and longevity as compared to an equivalent system fitted with flexible rubber hoses through near-elimination of hose expansion.
The difference in expansion characteristics between rubber and braided stainless steel brake lines is a result of differences in hose construction. Where rubber hoses typically consist of a rubber inner hose wrapped in a textile reinforcement braid then covered in an additional rubber outer sheath, braided stainless steel hoses typically consist of a Teflon or generic PTFE (polytetrafluoroethylene) inner hose wrapped in a braid consisting of stainless steel wire.
The stainless wire braid more effectively resists expansion due to pressure inside the hose core. This improves brake system effectiveness by more directly transferring operator input (hydraulic pressure) to brake friction surfaces. While available without a coating, the stainless braid is typically coated or covered with a clear or colored material such as PVC (polyvinyl chloride) to protect the wire and inner hose from the elements and chemicals, to protect the vehicle or machine from abrasion, and for an improved appearance.
Coated braided stainless steel hoses have the same essential construction as rubber hoses in terms of an inner hose wrapped in a braid followed by an outer layer, but the different materials in the braided stainless steel hoses offer substantially different and arguably better characteristics.
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade.
ARH 1 7/8 headers, CAI, BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings, DSS driveshaft ...421 whp...so far.
Old 05-20-2013, 04:04 AM   #16
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
Originally Posted by OldJedi View Post
What engine and cooling mods did you make so far?
10% OD lower pulley
Rotofab CAI
Running Torco at 98 Octane
Intercooler recevoir
Upgraded H/X
I do not really need more power for the road course. I am close to about 575rwhp. I would rather focus on handling improvements and weight reduction at this point.
69NMYSS is offline   Reply With Quote
Old 05-20-2013, 07:36 AM   #17
Exigent
Drives: 2003 Porsche 996tt
Get track tires, you'll be amazed at the difference.
Exigent is offline   Reply With Quote
Old 05-20-2013, 12:35 PM   #18
zl1bro
Drives: 2013 ZL1 M6 SIM AGM mono stripe
What about the tires they are putting on the new Z/28? Do you think these would be a good track tire for the ZL1?
zl1bro is offline   Reply With Quote
Old 05-20-2013, 12:49 PM   #19
THR ZL1 #1
Perma Grinning
Drives: 2012 Tom Henry Racing ZL1
Originally Posted by DrkPhx View Post
Two questions: Can you weight those rotors and compare them to stock?
Just did rotors on my ZL1 . . weighed them myself.
Front: Stock rotor 27 lbs. RB floating 2 piece 22.5 lbs.
Rear: Stock rotor 23 lbs. RB floating 2 piece 18 lbs.
Total weight loss . . 19 lbs.
Car's I drive:
2017 Tom Henry Racing ZL1 Convertible, 2016 Silverado High Country HD, 2014 Camaro SS Convertible, 2014 Acadia Denali, 2012 Tom Henry Racing ZL1, 2002 Berger SS Phase II, 2001 Camaro SS Convertible, 1997 Hendrick Motorsports 30th Anniversary LT4 SS, 1992 Camaro RS Z03 25th . . .
THR ZL1 #1 is offline   Reply With Quote
Old 05-20-2013, 03:53 PM   #20
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
if your sessions last 25 min like mine, the factory radiator may need to be swapped to a better unit to keep engine coolant temps down. My car would creep to 240+ on a 75 degree day. With my Dewitts unit, the temp was highest in the 230 range.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 05-20-2013, 04:02 PM   #21
69NMYSS
69NMYSS's Avatar
I would love a set of R compounds. But this is my DD. I will probably end up getting a set of dedicated 19" wheels and r comp tires for the track.
Old 05-21-2013, 12:28 AM   #22
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
How did you decide on the brake compounds? Why the split DTC-30 and HT-10 vs DTC-30 or DTC-60 all the way around?
Bryan 695 SAE RWHP 2012 ZL1 9.55 pulley custom cam and Kooks headers, 2002 Z06 447 RWHP, 2006 Trailblazer SS, 1995 S/C Vortech Trans Am 570 RWHP(for sale)
ZO6 Bryan is offline   Reply With Quote
Old 05-21-2013, 03:17 AM   #23
NightmareZL1
Can't stop ***ifying
NightmareZL1's Avatar
Drives: Ashen 2013 Gray ZL1
Pirelli just released a 20" version of the trofeo R tires that are on the Future Z/28. But a few guys in the Z28 forums are positive that it won't make the ZL1 any faster on a track - hahaha.
Pretty sure they will help, Pirelli used the same rubber that is in thier Slick race tires for these.
Rotofab, grinding rear diff sound forever, dealer replaced supercharger - now i have a rattle when starting from a stop, ordered 2.35 lingenfelter pulley, hp tuner, belt, 100mm idler pulley, tr7IX spark plugs, wideband kit, long tubes with no cats...hoping for 650hp. dyno with rotofab = 518hp
NightmareZL1 is offline   Reply With Quote
Old 05-21-2013, 02:41 PM   #24
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
I know what tires I'm going to try next when I wear these Goodyear F-1's out.
ZL1-V is offline   Reply With Quote
Old 05-21-2013, 02:54 PM   #25
ZR1/2SS
ZR1/2SS's Avatar
Drives: 2002 CETA, 2011 CTS-V
Nice build OP you have underway.
btw...That's some straight bullshit that some punk ASSes stole your wheels man!
ZR1/2SS is offline   Reply With Quote
Old 05-21-2013, 03:54 PM   #26
Exigent
Not sure how much you intend to actually track the car but a heavy car on street tires won't be very satisfying, the heat generated will be more than your street tires are designed to handle. I have friends who swear by Michelin Pilot Super Sports, although on much lighter cars, and the new BFG Rival is getting good reviews in the auto press. If you can't/don't want to spend $ on a set of track wheels/tires the PSS may be a good place to start. Didn't realize it was your DD, when I saw the thread title I thought you were building a hard core track car.
Spend your $ on driver education, that's where the gains are made. You're going to really enjoy getting out on track and learning to drive the ZL1,
Old 05-21-2013, 05:12 PM   #27
69NMYSS
69NMYSS's Avatar
I have about 20 track days in my ZL1 running in high advanced group. I have spent a couple grand on private lessons, not sure if spending more $$ on drivers ED is going to be the best use of money at this point. I think focusing on improving the handling capabilities of my car coupled with more seat time is going to yield the best gains.
The PSS's will be my 4th set of tires on my ZL1, and I am on my 5th set of rotors/pads. The GY G:2's were great, but I have heard really good things about PSS's so i thought I would give them a shot. I do plan on purchasing a dedicated set of track tire/wheels, but wanted to build up the suspension components first.
Old 05-23-2013, 01:08 PM   #28
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Nice! Can't wait to hear back from you after you've burned around some corners!
