Old 05-19-2013, 04:02 PM   #1
IC1Patton
IC1Patton's Avatar
Drives: 2017 Camaro 2SS
OVERHEATING AFTER CAM INSTALL
I installed a new cam and and now its overheating. Am i missing a step that i dont know about. i changed the thermostat after it started overheating. i dont believe it to be the pump cause it worked just fine before. is there a way to prime the pump or test operation?
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived." - General George S. Patton
IC1Patton is offline   Reply With Quote
Old 05-19-2013, 04:03 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Tune?
Click to view my build thread
Old 05-19-2013, 04:05 PM   #3
IC1Patton
IC1Patton's Avatar
i loaded a new tune from jre
Old 05-19-2013, 04:08 PM   #4
The Stig
The Stig's Avatar
When you say changed the thermostat after overheating. Was that back to a stock 180?
Old 05-19-2013, 04:11 PM   #5
IC1Patton
IC1Patton's Avatar
yep 180 from
napa
Old 05-19-2013, 04:12 PM   #6
Demon Z/28
Scarecrow
Demon Z/28's Avatar
Drives: like a granny
fans plugged in ? are they coming on ?
The Rooster - 2015 Z/28
The Scarecrow -2014 1LE SOLD -
Demon Z/28 is offline   Reply With Quote
Old 05-19-2013, 04:13 PM   #7
IC1Patton
IC1Patton's Avatar
yep fans are working
Old 05-19-2013, 04:14 PM   #8
The Stig
The Stig's Avatar
What's your coolant temp at?
Old 05-19-2013, 04:15 PM   #9
IC1Patton
IC1Patton's Avatar
it hit 230 and still climbing before i shut it down
Old 05-19-2013, 04:19 PM   #10
Deftones
Deftones's Avatar
Drives: 2012 RS/SS LS3
Try a oem tstat. After market tstats fail more often then not.
Deftones is offline   Reply With Quote
Old 05-19-2013, 04:30 PM   #11
Demon Z/28
Scarecrow
Demon Z/28's Avatar
head gaskets for sure on correctly? they CAN go either way. may just have big air in the system still. to bleed the system i like to give it some revs, helps the flow change and in turn helps with the air. also sometimes it's better to have the cap on it, let it get above 200, then shut her down. squeeze the hose at the thermostat to radiator. which reminds me, is that hose getting hot ? compare your top hose tot he lower hose, feel the same ?
Old 05-19-2013, 04:30 PM   #12
sycraft
COTW 5/06/2013
sycraft's Avatar
Is there a air pocket in the system, leave the cap off and run let the coolant flow, you should see it move, it may burp several times too.
Old 05-19-2013, 04:37 PM   #13
stikSS
9691 & 97586
stikSS's Avatar
Drives: '10 Camaro SS and 2LT
This.... u have to let it run with the cap off and slowly add water and anti freeze till you get it full again.
Sent from my Apple sued Galaxy Note 2
stikSS is offline   Reply With Quote
Old 05-19-2013, 04:46 PM   #14
IC1Patton
IC1Patton's Avatar
i didnt remove the heads i will try that with the revs at 200* and see if that helps and the hoses are not the same temp
