Emblempros
Old 05-19-2013, 08:37 PM   #1
OptimusPlez
OptimusPlez's Avatar
Drives: 2013 Camaro 2SS RS 1LE GBA
Question Winter Tires on a 1LE
Need some help from the tire experts on the forum. I used 245/55R18 Pirelli Scorpion tires on 18X8 5-120 ET40 MODA MD6 rims in the winter on my 2010 2LT RS. I only have two winters on those wheels and would love to keep using them on my 1LE in the winter. Can anyone tell me if these will fit my 1LE. I thought I better figure this out now if I need to start saving money for a new winter set.
OptimusPlez
2013 2SS RS 1LE GBA -aka- BLACK BEAUTY
Factory NPP
Polished Roto-Fab CAI
Cilajet Sealant
OptimusPlez is offline   Reply With Quote
Old 05-19-2013, 08:55 PM   #2
Bad@ssCamaro
Rogers' Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
Do you have the "rollerskates" on the brake pads? If so, you could switch out the pads to ones without and try to fit them on. I would be curious if you could do this, because I want to do the same.
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade.
ARH 1 7/8 headers, CAI, BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings, DSS driveshaft ...421 whp...so far.
Old 05-19-2013, 10:10 PM   #3
SPCBA
Drives: pleather and Chiclets
dont think the 18s will fit with your sways.
SPCBA is offline   Reply With Quote
Old 05-20-2013, 01:24 PM   #4
x3speed
x3speed's Avatar
Drives: 2013 Victory Red 1SS/1LE w/ DME
18's will not fit. Worked this out with Rudy. Need 19's
Current Car:
2013 Victory Red 1ss/1LE w Dual Mode Exhaust
"If you love something set it free. If it doesn't come back, hunt it down and kill it."
x3speed is offline   Reply With Quote
Old 05-20-2013, 02:11 PM   #5
Bad@ssCamaro
Rogers' Rocks :-)
Thanks for the info
Old 05-20-2013, 02:16 PM   #6
snickerdoodle
Drives: 2013 1LE AGM 2SS RS M6
i ran continental dws 285 25 20 on my stock 1LE rims and had a great time driving through the snow as others were stuck
snickerdoodle is offline   Reply With Quote
Old 05-20-2013, 02:25 PM   #7
Bad@ssCamaro
Rogers' Rocks :-)
you ran a square setup for the winters too? is the 25 correct? seems a little low profile for winters
Old 05-20-2013, 10:25 PM   #8
OptimusPlez
Thanks for the feedback. That is what I was afraid of. Looks like either winter tire and rim package or winter tires on stock rims.
OptimusPlez
Factory NPP
Cilajet Sealant
Old 05-20-2013, 10:52 PM   #9
Cooley
Cooley's Avatar
Drives: 2013 2SS 1LE
You can run some 19's, some you can't. 18's definitely will not fit. I recommend getting with Rudy at Tire Rack.
Cooley is offline   Reply With Quote
Old 05-21-2013, 12:40 AM   #10
snickerdoodle
Sorry, the sidewall is actually 30 mm. The ride is as good if not better than a standard SS with this profile.
I was expecting hydroplaning with this width the square setup and awful snow traction... but this was not the case at all! I didn't even get stuck even while in upstate NY with about 9 inches of snow, I stopped to help a m series Mercedes truck that flipped over! In the dry I am fairly satisfied with the performance as well.
The Conti's are noted for having mushy sidewalls, but I cannot agree after 10,000 miles. I drive the car HARD and the wear pattern on these tires is phenomenal. Going to put on the summers as soon as possible the feel the difference.
If anyone wants to talk in depth about my experiences with these tires, pm me and I will give you my phone number.
Here's a link to the tires. A set of 4 runs just over a grand.
http://www.tirerack.com/tires/tires....WSXL&tab=Sizes
