Solo Performance
Old 05-20-2013, 09:41 AM   #1
Jason P
Jason P's Avatar
Drives: 2011 2ss
Car makes 11 lbs boost???
With all the reading I have been doing I figured I would be losing boost. My cam specs are 231/243 .617/.624, I also have ported and polished stock ls3 heads with 1 7/8 long tube headers. I didn't plan on supercharging my car but Jessika made me such a good deal I couldn't pass it up, so I bought a magnuson 2300 with the overdrive pulleys. Just looking for one of the experts thoughts. Like I said before I figured boost would be less. (5-7 lbs)
2011 2ss Ram twin plate ceramic clutch, Texas speed 418 LS3 235 /243 .621 / .624 cam, ported and polished heads with dual springs,magnum push rods, Hotchkis race pack, Stainless Power long tube headers with no cats, Magna Flo competition exhaust, lpe fuel pump, magnuson supercharger with overdrive and port matched blower plate, IW 8 rib pullies, AEM meth kit, id 850 injectors, 3 bar map, halltech cai, zl1 rear diff
Jason P is offline   Reply With Quote
Old 05-20-2013, 09:49 AM   #2
bct10985
Drives: 2010 2SS LS3, 2013 duramax
My car made 11.5psi on the dyno with a stock ecs kit and longtubes, which i thought would actually bring down the boost a bit. Was expecting around 8-9.
ECS Novi 1500 supercharger, FSP cam, Tsp 2" longtubes, Squash dual pumps, Id850s, Aem meth, Jakes stageIII 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 17" weld rts 4.5" M&H skinnies front, carlyle racing 15" conversion mt 325 et street R. 10.41@133mph
bct10985 is offline   Reply With Quote
Old 05-20-2013, 09:59 AM   #3
Jason P
Jason P's Avatar
Drives: 2011 2ss
Are you running a NA cam also? I thought I would be less boost with the cam, heads and headers. Not complaining, car runs awesome, just not what I was expecting. Ihave spent hours reading threads about overlap, losing boost out the exhaust valves, lower boost with ported heads, etc. Now just looking for a better education.
Old 05-20-2013, 10:01 AM   #4
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
I made 15.3lbs of boost on my NA cam with the ECS Kit.
VanquisherSS is offline   Reply With Quote
Old 05-20-2013, 10:14 AM   #5
EliteCZM523
EliteCZM523's Avatar
Drives: 2010 2SS/RS
This would be why.
ARH 1 7/8 w/ cats, Borla ATAK Axle Back, VaraRam, ECS Cam, JDP Halo Kit, Technostalgia Tail Lights, AAC Ghosted SMD Side Markers, Reverse Lights, P13W Plasma DRL's, DRL Harness, Kenwood 9990HD, Scosche Kit, and tons more
EliteCZM523 is offline   Reply With Quote
Old 05-20-2013, 10:32 AM   #6
bct10985
Stock ls3 cam
Old 05-20-2013, 11:05 AM   #7
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
plus if you have cats on the car it will create restriction in the exhaust which will increase boost levels.
xjer22x is offline   Reply With Quote
Old 05-20-2013, 11:37 AM   #8
Jason P
Jason P's Avatar
Drives: 2011 2ss
No cats.
Old 05-20-2013, 11:45 AM   #9
bct10985
No cats
Old 05-20-2013, 12:22 PM   #10
EliteCZM523
Drives: 2010 2SS/RS
Two different types of blowers, One is a PD, other is Centri. The ECS kit runs a bit more boost then the PD does. Also, OD pulleys will increase Boost levels.
Old 05-20-2013, 01:00 PM   #11
old motorhead
Drives: Maggie blown LS3 vette
What size pulley do you have up front? I think it takes a whole lot bigger cam with more overlap than you have to really "bleed" boost.
old motorhead is offline   Reply With Quote
Old 05-20-2013, 01:21 PM   #12
Jason P
Jason P's Avatar
Drives: 2011 2ss
Stock pulley up front. And you just kinda answered my question. I guess I wanted to know when I started to lose boost.
Old 05-20-2013, 01:24 PM   #13
bct10985
Just sayin they advertise 9lbs and i thought with the headers and no cats it would of been a little less.
Old 05-20-2013, 02:11 PM   #14
Jessika
Drives: Anything Blown
First off,
The 3.8 front pulley and 1:1 rear should make 6ish. The OD on the rear should put it to 9.5ish.
Lately it seems like everyone is making more boost than in the past... it is odd. Anyway, do you have a dyno sheet? Just curious...
Brandon/Suxost or however it is spelled also is making higher than average boost but he is running HF cats.
Jessika is offline   Reply With Quote
