Old 05-20-2013, 04:17 PM   #15
Jason P
Jason P's Avatar
Drives: 2011 2ss
No dyno yet haven't had time. Just going off gauge. (aem)
2011 2ss Ram twin plate ceramic clutch, Texas speed 418 LS3 235 /243 .621 / .624 cam, ported and polished heads with dual springs,magnum push rods, Hotchkis race pack, Stainless Power long tube headers with no cats, Magna Flo competition exhaust, lpe fuel pump, magnuson supercharger with overdrive and port matched blower plate, IW 8 rib pullies, AEM meth kit, id 850 injectors, 3 bar map, halltech cai, zl1 rear diff
Jason P is offline   Reply With Quote
Old 05-20-2013, 05:49 PM   #16
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
You probably have a smaller pulley up front.
Mchlgrrsn is offline   Reply With Quote
Old 05-20-2013, 06:12 PM   #17
fourmz
Fourmz
fourmz's Avatar
Drives: 2010 2SS/RS 1968 Firebird 1994 Z28
I too installed the OD cog kit last year and went from 8# to 11.5-12#.
Black-in-Black/Blue out 2010 2SS/RS LS-3 -Magnacharger TVS2300,OD cog belt drive, 3.4" pulley, Janetty smooth idle blower cam,ID-850 injectors,ZL1 fuel pump,MSD boost a pump, ADM FPCM Janetty custom tune,Doug Thorley long tube headers, Corsa catback,C.A.I. Intake, Roto-Fab Big Gulp Scoop, Monster LT1/SC Clutch assembly,Eibach pro kit plus, BMR cradle/diff bushings, Barton Shifter,JRE 3.91 Eaton Tru-Trac rear diff,Barton Short Throw SHifter, Boss 339 20" wheels,Painted heritage grille, Sparks Restoration Inverted blue/black SS emblems, Seibon BB carbon fiber hood, ZL1 front bumper conversion.
fourmz is offline   Reply With Quote
Old 05-20-2013, 06:43 PM   #18
old motorhead
Drives: Maggie blown LS3 vette
If you have the 3.8" front pulley, it's like having a 3.25 front if you had direct drive (1:1) on the rear. 11psi is about right. Don't fall in to the trap of thinking you need a "blower" cam. If you're good with the manners and fuel eco, there's no reason to change it. I'm guessing you don't have any low power problems on the bottom end. Full boost available at anything over 2500 rpm kinda cures that That's enough cam that it must absolutely scream up top. Enjoy it and don't worry about a cam swap.
old motorhead is offline   Reply With Quote
Old 05-20-2013, 07:35 PM   #19
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
OD Cog drive is worth 3.5 lbs of boost. Stock 3.8 Pulley with the Maggie in 6lbs of boost. 3.6 Pulley adds another 3lbs or so of boost. I run 12-12.5 lbs of boost, with Meth as safety.
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 05-20-2013, 08:06 PM   #20
old motorhead
The O/D rears spin the blower roughly 17% faster than the 1:1 rears. At mild boost levels, the boost will increase around 17% with the O/D rear pulleys vs the 1:1 set. As boost goes up, that % increase goes up too. If you spin the blower faster, pushing more air through the same motor, boost (restriction in this case) will go up. Just because the boost goes up doesn't mean the power will go up at a similar increase. At very high boost levels, adding more boost does little more than heat the air.
That's where bigger cams, ported heads, better exhaust, and anything else that adds to the air flow through the motor helps make more power.
Old 05-20-2013, 08:17 PM   #21
Kronix
Kronix's Avatar
And that's exactly what I did, adding my custom grind Comp Cam was one of the best mods I've done
Old 05-20-2013, 08:58 PM   #22
old motorhead
It's just bad a$$ed when you get it right. Nice sound, stock like MPG, and stupid power when it's all said and done. You guys are spoiled just rotten. Looks sweet, runs supercar fast, doesn't cost supercar money, and your wifes/significant others like it too
Old 05-20-2013, 09:21 PM   #23
Kronix
Kronix's Avatar
Well, you almost nailed it! My wife HATES getting in the beast But that's fine with me!
Old 05-21-2013, 12:37 AM   #24
Jason P
Jason P's Avatar
Drives: 2011 2ss
Thanks for the replies. I need to get it on a dyno and see where I'm at. Its all been pieced together from lurking on this forum.
Old 05-21-2013, 04:39 AM   #25
Slickcas
Drives: 12' 2SS/RS LS3 IBM
On a stock motor any thing more then 10 psi boost is asking for bad things to happen. With my little V3 with a 3.33 pulley I was at 11.5 psi and 618rwhp. I picked up a 3.47 pulley to get the boost down to 10 or so. As long as you are not running the car to hard you should be fine.
Slickcas is online now   Reply With Quote
Old 05-21-2013, 08:28 AM   #26
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
I run the OD cog and stock 3.8 pulley up front on my Maggie. I also have the JRE blower cam, and Kooks headers no cats. Currently making 9.6 psi peak boost. I would like to reduce boost by about 1 psi as I am on the edge with my fuel system and I can't hook up the power on the street anyway...
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 05-22-2013, 04:50 PM   #27
ayousef
ayousef's Avatar
Drives: 2013 ZL1
dont stress on how much boost you're making. If its too much for your taste get a larger blower pulley, but on the 11psi range and a stock motor (guessing) Youd better be running meth or a really good tune (yet i havent calculated dynamic compression ratio with your cam) Just make sure you have enough fuel pressure and stable WOT AFR and timing (no knock) and you should be good.
That cam you have will seem to make good top-end, which is a good combination with a PD blower since you already make awesome low-end.
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 05-22-2013, 08:40 PM   #28
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
I'm have a 223/235 .610/.620 115. Ported heads, OD Cog and stock front pulley and I'm at 10.5 psi.
Nitroman28 is offline   Reply With Quote
