BORLA
Old 05-20-2013, 05:53 PM   #1
ayousef
ayousef's Avatar
Drives: 2013 ZL1
1le wheels and tire concern for 416 Whippled 1le
Hey guys,
This is an all out max effort whipple 2.9 build on a 2013 1le straight off the factory floor.
Im trying to understand for starters if the wheel widths are the exact widths as the ZL1 wheels. I know the diameter is the same, just concerned about the widths since the ZL1 comes with a 315mm tire in the back, and if the width was the same the wheel would be sticking out in an ugly way with a 285mm tire.
Anyone try to stagger tire widths on a 1le? I know the squared tire dimensions has shown to be superior on the track but for a high hp vehicle that will never see track duty and mostly require straight line acceleation grip, do you think its possible to run a 315mm tire in the rear and a 285mm tire up front without running into any issues with ABS or traction control kicking in due to the different diameter ratio between the front/rear tires?
Thanks in advance!
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 05-20-2013, 06:15 PM   #2
snickerdoodle
Drives: 2013 1LE AGM 2SS RS M6
the stock rear tire width on a ZL1 is 305 mm. You can run a staggered setup without the ABS/Traction control interefering interfering.
snickerdoodle is offline   Reply With Quote
Old 05-20-2013, 06:20 PM   #3
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
1LE comes with the same exact wheel setup as the ZL1, 20x10 Front 20x11 rear, a 315 would look proper on the 20x11 or the 305 that comes stock on the ZL1
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 05-21-2013, 12:49 AM   #4
t&t moyer
It's all hers.
t&t moyer's Avatar
Drives: 2015 ZL1
ayousef,
Off topic, sorry.
Ah I was wondering who the 416 was going to. I was up to New Era a bit ago and the Whipple for this car was still setting in the office, that whole build is gonna be a beast!!! My 1LE will be going up to them for a tune soon. The 416 caught my attention and I might just have to look a bit more into something similar.
Cheers - Todd
Originally Posted by ayousef View Post
Hey guys,
Thanks in advance!
t&t moyer is offline   Reply With Quote
Old 05-22-2013, 06:58 AM   #5
ayousef
ayousef's Avatar
Drives: 2013 ZL1
Originally Posted by t&t moyer View Post
ayousef,
Off topic, sorry.
Cheers - Todd
Todd,
No problem! That car is for a friend of mine who lost his mind after I started my build so its actually headed over to Dubai when its done! should be an insane daily driver when its done.
