BORLA
Old 05-21-2013, 08:30 AM   #1
dreeve
dreeve's Avatar
Drives: 1993 lt1 z28
'93 z28 build
just wanted to share some of my build, couldn't find all the pics I wanted but most of the important stuff. started with taking out the whole subframe, rolled it into the garage and went to work. motor came off first and was disassembled and sent to the machine shop for new rings bearings etc. put a small erson cam in(which will not be in there very much longer.) scorpion 1.6 rockers, heads ported/polished(another mistake), edelbrock intake, bbk 52 mm tb, 30mm accel injectors, lunati lifters, new springs, msd opti cover with wires and coil, cloys timing chain, new chain cover, bosch +4 plugs, dougs shortys with a magnaflow highflow cat and cherrybomb muffler, pcmforless tune, it has canton racing valve covers just couldn't find the picture of that at the moment, rk sport ram air intake, bmr full front suspension( rear will be don't in the winter months) and today I will be getting my new monster trans with 2500 stall and my 3.73's! will post more pics as I can find them and before during and after tranny install!
1993 lt1 z28,BBK 52mm throttle body,accel 30lb injectors,edelbrock intake,port/polished heads,1.6 rockers,erson 222in/226ex .480 lift cam,Dougs shorty headers,pcmforless chip,RK Sport competition intake , monster transmission, 3.73's, bmr suspension
[IMG][/IMG]
dreeve is offline   Reply With Quote
Old 05-21-2013, 07:21 PM   #2
speedmon
Drives: C6 Z06
Any thoughts on how much power that thing makes?
speedmon is offline   Reply With Quote
Old 05-23-2013, 09:16 AM   #3
dreeve
dreeve's Avatar
the machine shop that ported the heads and ordered my cam said around 380hp, so I m gonna go with that until I can get him on a dyno
[IMG][/IMG]
Old 06-05-2013, 11:19 AM   #4
Ivan @ Southwest Speed
You had me at the cinder blocks holding the car up...subbed! LOL
Cool rig man. Keep it rollin!
Ivan
Old 06-05-2013, 11:27 AM   #5
steveo9043
steveo9043's Avatar
Drives: 2012 45th AE 2SS Coupe
when you said opti I started to cry! Man I hated that!
Ever thought about the opti to coil pack conversion?
http://www.fullthrottlespeed.com/ite...50LTCC+eq++Tp+
steveo9043 is offline   Reply With Quote
Old 06-06-2013, 08:31 AM   #6
dreeve
dreeve's Avatar
thats a pretty good idea steveo9043. what would I do with my opti though, like what would replace its spot on the motor?? and thanks ivan@southwestspeed! I would upload more pictures but my computer is all screwed up and wont let me
[IMG][/IMG]
Old 06-06-2013, 08:36 AM   #7
dreeve
dreeve's Avatar
ironic thing is..i have to pull the motor again bc of a head gasket leak, timing chain cover leak and a new motor mount.... :( so that is a possibility, along with a bigger cam
[IMG][/IMG]
Old 06-10-2013, 02:11 PM   #8
steveo9043
steveo9043's Avatar
from what i remember the opti is still there but it does not use the high voltage in the opti, its passed to the coils. Which drastically prolongs the life of the opti (still have to worry about the water pump tho).
Edit: this is on the part information
This unit still uses the factory optical module in the Optispark for reference, but no high voltage is passed through it. This removes the source of damaging ozone that eventually leads to Optispark failure.
2012 45th L99 SS-Cold air inductions CAI-Dynatech LT's-Solo mach XL catback
333hp/341tq (before LT's)
Old 06-10-2013, 03:05 PM   #9
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Those pretty red BMR parts will look good under the car onec you get everything back together!
T.C. Davis
Sales Tech, Test Driver
813-986-9302
tc@bmrsuspension.com
Old 06-10-2013, 07:29 PM   #10
joelster
Drives: '94 Z28+ '14 1LE
BMR makes some good shit! I have their extreme duty drag bar in my 4th gen. It makes the stock sway bar look like a pencil. Car leaves perfectly level now.
'94 Z28, 414" LT1, 10.15 at 133.65 N/A pump gas
'14 1LE, NPP, 12.991 at 109.40
joelster is offline   Reply With Quote
Old 06-16-2013, 01:06 PM   #11
dreeve
dreeve's Avatar
yea I love the bmr suspesnsion. even though my front sway bar is rubbing against my harmonic balancer....still waiting to hear back from bmr about that one.
[IMG][/IMG]
Old 06-17-2013, 09:28 AM   #12
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Let me look into this for you and I will get back to you on it.
T.C. Davis
813-986-9302
Old 08-17-2013, 01:32 PM   #13
dreeve
dreeve's Avatar
well I am going to rebuild the motor again this winter...bigger is better so I will be replacing the motor mounts and that should solve the problem like we talked about over the phone. and I will also be installing bmr suspension in the rear along with 1" lowering springs
[IMG][/IMG]
Old 08-18-2013, 03:42 PM   #14
dreeve
dreeve's Avatar
some more pics of the build. and minor re-build..
[IMG][/IMG]
