BeckyD @ James Martin Chevy
Old 05-21-2013, 09:27 AM   #1
Yumacamaro
Drives: 2013 2ss
throttle body porting
a week ago a friend had his TB ported by a professional. he has had a check engine light on and off since... now he says its sputtering and popping.. the strange thing is that others had their cars done also without any issues.that same day. the guy did a total of eight and the one with the problems was first. his is a 6cld but so were 5 others... any thoughts? also now that i remember it he installed a cold air intake from specter.... the box didnt differentiate that it was for a 6 or 8 cld car..
Yumacamaro is offline   Reply With Quote
Old 05-21-2013, 09:39 AM   #2
less2010
less2010's Avatar
Drives: 2010 2ss camaro
It sounds as though it will need a tune.
less2010 is offline   Reply With Quote
Old 05-21-2013, 10:12 AM   #3
BAWLZ SS
BAWLZ SS's Avatar
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova
You shouldn't need a tune if all u have is a ported TB and a cold air intake! Maybe his TB electronics went bad and that is what is causing that. He should also check if his TB was installed correctly! I have a lot more mods than just a ported TB and a CAI and still don't know what a check engine light looks like as it has never popped up on my dash as of yet. knock on wood!!!
Performance- Kooks Headers w/HF cats, ZL1 Corsa exhaust, VMax, CAI Inc. CAI, MGW shifter, RX CC Suspension - KW V3 Coilovers/ Full PFADT & BMR suspension Appearance - ZL1 Fascia/Sides/ Diffuser, AAC Afterburners, RK Sport 3pc Spoiler, SLP Black out Kit
BAWLZ SS is offline   Reply With Quote
Old 05-21-2013, 10:21 AM   #4
2012REDSS
Drives: 2012 Camaro SS
whats the code? Autozone or Advanced Auto should be able to read the code and tell him what it is. Id start there.
2012REDSS is offline   Reply With Quote
Old 05-21-2013, 10:27 AM   #5
Synner
Drives: not stock
vacuum leak or he ruined the TB most likely, read the code.
Old 05-21-2013, 11:39 AM   #6
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Might wanna check if his MAF sensor is weak.
http://www.camaro5.com/forums/showthread.php?t=291436
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
Last edited by BubbaSS; 05-21-2013 at 12:00 PM. Reason: added link on how to check MAF sensor
BubbaSS is offline   Reply With Quote
Old 05-21-2013, 01:38 PM   #7
BAWLZ SS
BAWLZ SS's Avatar
+1 That too!
Old 05-21-2013, 02:10 PM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
And this is why you stick to a VMax ported TB. They are CNC ported. Humans can make a mistake....computer rarely does.
Build Journal
Old 05-21-2013, 05:24 PM   #9
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Vacuum leak or weak maf sensor or over ported is the first thing I would expect.
I put one on a 2006 gto for a guy once and I pinched the o ring and it drove fine overall but had a couple of issues here and there similar to what you posted.
Bo White is online now   Reply With Quote
Old 05-21-2013, 06:25 PM   #10
SC2150
Good advice right there. Vry few "professional porters" can get it right by hand porting.
Bo knows. He gets it right.
