BORLA
Old 05-22-2013, 02:44 AM   #1
jbrantner24
Drives: 2013 Camaro LS M6
N/A performance
So I have seen the fast list and people in mid 13's with bolt ons, tune and drag radials. So anyone else think its possible to make 12's with the same setup plus cams and taller gears? I believe it can be done.
K&N intake, Resonated X-pipe w/muffler delete, Trifecta Tune, rashes up sport muscle tachs.
jbrantner24 is offline   Reply With Quote
Old 05-22-2013, 03:09 PM   #2
LS1346CID
Enjoying the lil things
LS1346CID's Avatar
Drives: 2012 Camaro RS Loaded - Lil Red
I would like to see that too!
It's all stock!
With the exception of : BrakePerformance slotted and drilled rotors, K&N filter, other misc bolt on's, Tint, Clear Bra, WhiteOut emblems, Painted Calipers
LS1346CID is offline   Reply With Quote
Old 05-23-2013, 01:46 AM   #3
LS3 Handler
I love the LS3
LS3 Handler's Avatar
Drives: 2010 IOM 2SS Manual
Yea that would be nice i have thought about gettin a used V8 M6 diff and throwin that under mine to see if the gears would help get her going with losing to much MPG at cruseing speed.
LS3 Handler is offline   Reply With Quote
Old 05-23-2013, 10:41 AM   #4
KMPrenger
KMPrenger's Avatar
I think its a long shot, but MAYBE possible. We've had this discussion in the past.
Only one or two N/A Mustang V6s that I know of have ran into the very high 12s, which included full bolt ons, tune, gears, and rims/tires.
Due to the extra weight, I don't think we will ever see better than low 13s with the same mods. Add cams into that picture and then maybe someone could squeak out a 12. Cams have only been attempted in one V6 so far, and that is Yellow_Glide's 2010 V6. He seemed to pick up around 25 - 30 rwhp with the cams alone, but then they added ported high flow heads to the build and after that it never ran perfectly from what I can remember. I think it runs decent, but the tune or something is holding it back.
Not to mention the power is moved well up into the rpms range. Low end power is lost but peak power is higher and I think moved well into the 7,000+ rpm range.
Old 05-23-2013, 12:07 PM   #5
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
I heard there is a NA (just Bolt Ons)Camaro v6 running a 13.1 I havent personally spoken or seen this person, but thats what i was told. I will probably go run mine before i swap out for my new tires.
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 05-23-2013, 01:40 PM   #6
KMPrenger
KMPrenger's Avatar
Yep, Tracy has been saying that. But thats one of those I'll believe it when I see the proof type things for me.
Old 05-23-2013, 02:33 PM   #7
SC2150
Although I doubt you can give an example where I have ever posted something not accurate here, can you? His has the stock converter also, but we just did 3:55 gears from the 3:27's so he thinks he can beak into the 12's now. We will see, and it's FL summer heat and humidity now as well for him to fight. He should post today I hope.
Give me a NA car and the budget and I'll get one in the high 12's. Been doing this for over 38 years and our old bracket car made only 341 to the rear wheels and we ran mid 11's wining big$ bracket races all over the Eastern US for years (200k miles before we sold it, started racing it w/24k miles....several stories on it in different race magazines, etc. over the years).
So yes, I think we can see one, but not a run-of-the mill bolt on.
Old 05-23-2013, 08:30 PM   #8
KMPrenger
KMPrenger's Avatar
Tracy, I wasn't calling you out. Anyone could be making those claims, but we need to SEE it as we have never seen anything close to it yet. So you can see where I'm coming from.
Hope to hear from this guy.
Old 05-24-2013, 02:19 AM   #9
jbrantner24
I believe it can be done. May take me a couple years but I'm planning on trying it.
Old 05-24-2013, 09:45 AM   #10
SC2150
Hopefully he will post his time slips. Left him a message yesterday.
