Old 05-22-2013, 05:32 AM   #1
nebchevy
nebchevy's Avatar
Drives: 2011 2SS SGM Camaro
Knock Knock....Whos there?
Well I just got done installing Holley LS Valve Covers, Spark Plug Wires, Fuel Rails and heater hose...
I started her up and there is was... a very loud TICKING sound that I have never heard before. She is not sounding very well either, seems like the ticking is making her run crappy..
Can Someone please help!! I have no idea why it would be ticking/knocking....
Thanks!!
nebchevy is offline   Reply With Quote
Old 05-22-2013, 05:58 AM   #2
vtxretro02
vtxretro02's Avatar
Drives: 2012 Camaro 2ss Heritage Grill/GFX
i would start with the spark plug wires.. make sure they are on tight.. you might be hearing the arcing of the spark and a a result it may not be firing on all cylinders
vtxretro02 is offline   Reply With Quote
Old 05-22-2013, 07:47 AM   #3
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
I have no experience with those valve covers but are they shorter than stock. Maybe a rockers touching them ? Nothing else you did could really cause this.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 05-22-2013, 08:08 AM   #4
NinoSS
Drives: 2SS/RS CGM LS3
Perhaps the valve covers are not a thick (or different type of material) allowing more noise from the valve train?
SOLD Vengeance stage I cam (442rwhp/412rwtq) / CAI intake w/ADM race scoop / Dynatech LT's / ATI udp / JRE tuned / Eaton Posi LPE-JRE 3.91's / L99 Corsa / Whiteline Sways & Bushings / UMI Trailing Arms & Toe Rods / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 05-22-2013, 08:33 AM   #5
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
The valve covers wouldn't cause a clearance issue. Make sure those wires are on firmly! Second when you installed the rail make sure the injectors are in properly as well. I bet one of those two are your issue.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 05-22-2013, 08:43 AM   #6
BAWLZ SS
BAWLZ SS's Avatar
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova
+1
Performance- Kooks Headers w/HF cats, ZL1 Corsa exhaust, VMax, CAI Inc. CAI, MGW shifter, RX CC Suspension - KW V3 Coilovers/ Full PFADT & BMR suspension Appearance - ZL1 Fascia/Sides/ Diffuser, AAC Afterburners, RK Sport 3pc Spoiler, SLP Black out Kit
BAWLZ SS is offline   Reply With Quote
Old 05-22-2013, 12:30 PM   #7
nebchevy
nebchevy's Avatar
Thanks to everyone!! I was up all night working on the car so i will get back out there and try everything you all suggest!!
Old 05-22-2013, 12:38 PM   #8
FosterSS
Guardians Of The Night
FosterSS's Avatar
Drives: Chevy
I would hope there isnt a clearance issue with these valve covers, I was about to put some on myself!
Not to insult your intelligence or anything OP, but you did swap out the rubber gasket to the new covers right?
EDIT: Nevermind, I can see the blue gasket in your other pics!
(SOLD)2011 SS LS3- All Black, Cammed w/ a few other mods...
1968 SS 396- currently being restored.
FosterSS is offline   Reply With Quote
Old 05-22-2013, 12:41 PM   #9
FosterSS
FosterSS's Avatar
Drives: Chevy
I'd start by double checking the plug wires and injectors though, thats really the only mods that can affect performance too? Hope you solve this bro.
Old 05-22-2013, 05:12 PM   #10
nebchevy
nebchevy's Avatar
Well Thanks to all and I WILL say the Vavle Cover are AWESOME!!
I still hear a tick.... I checked all my plug wires and ever took them all off and installed the factory ones but still the same..Do you really think the new value covers arent tall enough??
Here is what I am thinking... I have never had engine cover off while running car and the factory value covers had more junk on them...
So i am thinking maybe there has always been a little tick in her but I could just never hear it?? Is that possible? I did take it out and drive it and it still hauls A$$...
Old 05-22-2013, 05:23 PM   #11
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
Is it just me or do the valve covers look photoshopped?? Especially from the sides. Also, are they supposed to have those dents?
Trentin24 is offline   Reply With Quote
Old 05-22-2013, 05:30 PM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
If the valve covers are thinner then YES ABSOLUTELY the rockers will be hammering them and in turn can damage some of your valve train. From the front view where you can see the thick blue gasket they look thin to me bud. I'd take them off and check the underside. Just my .2
Old 05-22-2013, 05:41 PM   #13
driyac
driyac's Avatar
Drives: 2012 45th Anniversary 2SS
The holley valve covers do not have any clearance issues guys. Everyone and their brothers have put them on without issue. Myself included.
driyac is offline   Reply With Quote
Old 05-22-2013, 05:41 PM   #14
nebchevy
nebchevy's Avatar
What are you talking about lol.... nothing is photoshopped...
