Cold Air Inductions
Old 05-22-2013, 04:36 AM   #1
Crand
Crand's Avatar
Drives: away the ladies :(
Send a message via AIM to Crand
Oil Smell
Recently I've noticed that when I switch the A/C system from recirculated air to fresh air and I'm idling at a stoplight, I smell burning oil like if I had spilled some on the headers during an oil change. This was late at night with nobody on the road anywhere near me and it was consistent every time I stopped. When I got home I popped the hood and couldn't smell it anywhere. No drips, no smears on anything, no smell AT ALL. Has anybody else experienced this? Anybody have any ideas what may be causing it?
Crand is offline   Reply With Quote
Old 05-22-2013, 03:25 PM   #2
Midnight Rat
Midnight Rat's Avatar
Drives: 2013 SS 1LE
My 2011 did the same thing. Never saw a oil,leak.
Midnight Rat is offline   Reply With Quote
Old 05-23-2013, 12:38 AM   #3
Crand
Crand's Avatar
The only thing I can find in the Interwebz is that the Camaro smells like oil sometimes. The fix is to ignore it.
Old 10-24-2013, 09:49 PM   #4
TOYMARO
TOYMARO's Avatar
Drives: 2011 Camaro SS/RS 2SS
old thread....but there are others. Rear main seems to be answer. Someone said a TSB was issued.
TOYMARO is offline   Reply With Quote
Old 10-24-2013, 09:51 PM   #5
aggieguy13
aggieguy13's Avatar
Drives: 2013 SS/RS VR 1LE
Belt might've just slipped
2013 SS/RS 1LE VR-Backup System, SOLO Perforsance HF Cats, Muffler Delete, BBK Off-road X-pipe
2002 35th Aniversary SLP SS-Sold
aggieguy13 is offline   Reply With Quote
Old 10-24-2013, 10:01 PM   #6
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
I get the oil smell too every once and a while, I like it!
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 10-25-2013, 07:59 AM   #7
Walker_1LE
Walker_1LE's Avatar
Drives: VR, 1SS/1LE, NPP, Camera, 1 of 76
I'm glad someone else has posted about this! I get the smell when my car is put on defrost... Almost runs you out when you're stopped! Possibly the rear main seal?
Walker_1LE is offline   Reply With Quote
Old 10-25-2013, 11:52 AM   #8
delphigto
delphigto's Avatar
Drives: 14 1le
Mine does it also.
06 gto Maggie 489 rwhp sold
05 gto ERL/HKE 454 609rwhp na sold
06 Z06 500 rwhp sold
10 2ss ERL 427 530 rwhp sold
14 1ss 1le
delphigto is offline   Reply With Quote
Old 10-25-2013, 12:10 PM   #9
1leNPP
Drives: 1LE , 1SS , NPP
Same here
1leNPP is offline   Reply With Quote
Old 10-25-2013, 01:06 PM   #10
wakespeak
wakespeak's Avatar
Drives: 2013 2SS LS3/NPP
I used to get it but fairly rarely. Never saw a leak so I assumed it was some kind of crankcase fumes. Now it seems like it stopped since I put on the GM oil separator. Are you guys that are getting the oil smell running with the separator on or off?
wakespeak is offline   Reply With Quote
Old 10-25-2013, 03:50 PM   #11
delphigto
delphigto's Avatar
Drives: 14 1le
Mine is on.
14 1ss 1le
Old 10-25-2013, 04:02 PM   #12
Stock Boy
Stock Boy's Avatar
Drives: 2014 1LE
Let me ask...is it a "sweet oil" smell, or just a plain acrid burnt oil? I had a an oil separator on my last veh which vented to the atmosphere. Strong odor that I thought was oil being burned but it turned out to be just the crankcase fumes. If it has sort of a sweet smell to it is probably just those fumes making it's way into the cabin through ac system.
Stock Boy is offline   Reply With Quote
Old 10-25-2013, 06:33 PM   #13
detox
detox's Avatar
Drives: 2002 ss camaro
Yea...oil seperator. Only the 1LE Camaro has it. It is not emmision legal, but some dealers install it anyway. It is packed in the trunk when dealer receives car...i read here.
http://www.camaro5.com/forums/showth...ight=separator
Ask this question in the regular SS section. Maybe someone has same smell without using seperator.
detox is offline   Reply With Quote
Old 10-27-2013, 01:07 AM   #14
Crand
Crand's Avatar
Imagine that. I was just thinking about resurrecting this thread. The problem I was having is that I overfilled the oil when I changed it. It didn't take much, just .5 of a quart was enough to do it. I'm not sure exactly why but I'm guessing that with the extra oil, the crankshaft whipping through it must create an oil aerosol that when ingested through the PCV system, smells like burning oil. The night I had the epiphany that this may be the cause, I checked the oil, it was high, I turned around and drained what felt like a quart and went back out. Smell gone.
Anybody else able to replicate my results?
