ADM PERFORMANCE
Old 05-22-2013, 07:13 AM   #1
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
vacuum leak?
I have a cel for p0201,03,05,07(driver side injectors) and the abs light. I discovered i have a brake booster leak that i suspect is throwing the abs code. what I want to know is if that leak could be my possible misfire on the cylinders as well?
Nightmare2012 is offline   Reply With Quote
Old 05-22-2013, 07:26 AM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
a vacuum leak could cause misfires yes
Click to view my build thread
Old 05-22-2013, 07:40 AM   #3
Nightmare2012
come find out;)
Even if its the brake booster leaking?
Old 05-22-2013, 08:17 AM   #4
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
I don't think a vacuum leak would set injector faults. Check ECM plugs for corrosion.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 05-22-2013, 08:43 AM   #5
BLACK10
BLACK10's Avatar
check your grounds!
Old 05-22-2013, 09:04 AM   #6
Nightmare2012
come find out;)
I have four grounds correct? One behind passenger head one on the block between the headers and the valve covers one next to the alternator on the block and one behind the driver side head. Now as speaking to litle88 he at first thought might be my battery so I took it to charge and they said it was charging just fine then he advised to check my hoses for any leaks. Although I found a leak on the hose of the brake booster behind the intake manifold I'm on the process for more possible answers. I couldn't see any corrosion to my connectors but I'm no expert so you guys tell me what you think thanks I appreciate the help.
Old 05-22-2013, 03:42 PM   #7
Nightmare2012
come find out;)
Tightened down the brake booster vacuum line and turned the car on and had an engine power reduced light come along with a service vehicle soon light and a service stability track light I don't have a code reader with me at the moment so don't know what could possibly be the codes. I also tried backing up the car and it just died on me out of no where.
Old 05-22-2013, 04:36 PM   #8
Nightmare2012
come find out;)
Old 05-29-2013, 09:34 PM   #9
BLACK10
BLACK10's Avatar
you DEF have an issue. be sure to check the fuses under the hood. sometimes they can back out. also check the ground on the front of the passenger head.
Old 05-29-2013, 09:55 PM   #10
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Nick he has melted pistons lol
Old 05-29-2013, 09:56 PM   #11
BLACK10
BLACK10's Avatar
oh damn, ill find the latest thread
